Touch Display 4.3 Development Kit
Development Kit Options
PCWHD
Tools
Compiler
Included
Sku
Compiler PCWHD
Software
Programmer
S-201
PCDIDE
Compiler
S-201
Hardware
Only*
53331-1612
LCD
Board*
53224-1611
PCDIDE
Prototyping
board
Power
supply &
cables
Exercise
book
*Hardware only and proto-boards are intended for customers already owning a CCS compiler.
The new Touch Display 4.3 Development Kit is all that is needed to develop a GUI using the Graphics and
Touch Library. Powered by a PIC24EP512GU810 it has a 4.3" 480x272 TFT display with a resistive
touchscreen, a 256 megabyte flash, capable of storing hundreds of 480x272 images and custom fonts, a USB
connection and 8 digital I/O pins that can be used for external inputs and outputs. No device programmer
required - includes onboard programming capabilites.
Included is a software IDE to draw out a GUI and the C library for drawing graphics and handling touch.
Draw an Image
Draw a Object
Handle Touch
Touch Display 4.3 Prototyping Board (Size: 4.75" x 2.63")
includes:
PIC24EP512GU810 Microchip PIC® MCU
8 I/O Pins
4.3" 480x272 TFT Display with a Resistive Touchscreen
256 Megabyte Flash
USB Connector
Micro USB Cable
Touch Display 4.3 Development Kit includes:
In-Circuit Debugger/Programmer
Exercise Book
9V AC Adapter and Cables
Development Tools CD with GUI Interface and CCSLoad Software
Interface Designer
A Simple, Fast Solution to Create GUI and Handling Touchscreen Function
CCS introduces a new Graphics and Touch Library and Interface Designer software in the CCS C Compiler.
This package has every thing you need to quickly and easily develop a Graphical User Interface (GUI) using a
graphics LCD and touchscreen. The package consists of a C library for drawing on an LCD and handling touch
input, a software package for designing a GUI to be displayed using the C library, and a development kit to get
started with the package very easily.
The C library displays bitmap images that are stored on an external memory device, for example an external
flash. The library provides the functions gfx_LoadImage() and gfx_EraseImage() for easily loading and
erasing images from the external memory. In addition the graphics library provides a method for loading and
displaying custom fonts. The functions gfx_LoadFont() and gfx_EraseFont() are provided to easily load and
remove custom fonts. The following is a list of functions in the library used to control what is displayed on the
graphics LCD:
gfx_InitGraphics()
gfx_DisplayImage()
gfx_RemoveImage()
gfx_RemoveAllImages()
gfx_ClearScreen()
gfx_RedrawScreen()
gfx_FillArea()
gfx_FillAreaAbsolute()
gfx_DrawLineAbsolute()
gfx_DrawCircleAbsolute()
gfx_DisplayString()
gfx_DisplayStringAbsolute()
For the touch portion of the C library the functions gfx_TouchTask() and gfx_SetTouchCallback() are
provided to use it. The gfx_TouchTask() function is a task function that needs to be called at least once per
main loop to process touches. The gfx_SetTouchCallback() function is used to set the user function that is
called by gfx_TouchTask(). In addition the gfx_InitGraphics() function needs to be called to set the calibration
values of the touchscreen.
http://www.ccsinfo.com/product_info.php?products_id=touch-kit 5‐3‐17
很抱歉,暂时无法提供与“53224-1611”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1161.884091+150.41594
