XD-900-0000-IE
XD-900-0000-IE
    DIGITALSIXLABS
    WHISKER.BLOCKXD BASIC BLOCK IP67
XD-900-0000-IE 数据手册
Basic Whisker.BlockXD™ General Description Whisker.BlocksXD™ are battery powered, long range wireless devices that can monitor the world around them from as much as 1 mile away or more. They are designed to be extremely flexible and can easily be configured to meet exacting requirements. The Basic Whisker.BlockXD™ is configured with an internal temperature sensor and two external digital inputs. The sample period for these inputs can be set by the user from 5 minutes to every 24 hours. Power Digital Six Labs offers a variety of antennas that are compatible with Whisker.BlockXD™: Part Number Size Cost Range INTERNAL Smallest Lowest Good TQX-900-A (AI) Small Good Better TQX-900-E Larger Higher Best Internal Channels As stated earlier, the Basic Whisker.BlockXD™ is configured to monitor three channels: internal temperature and two external digital inputs. The Basic Whisker.BlockXD™ is powered from a field replaceable internal battery pack which will last 5+ years with a 5-minute sample period. This block can optionally be configured with a long-life battery pack capable of extending operate to 15+ years. The internal temperature sensor is accurate to within +/- 3°C. Antenna External Connections The Whisker.BlockXD™ can be configured for an internal or external antenna. External antennas are connected via an RPSMA connector, allowing the customer to select the antenna that is appropriate for the application. It is important to select the proper antenna for the application. Generally, smaller or less expensive antennas will exhibit lower performance and therefore less transmission range. © 2017 Digital Six Laboratories Inc Up to two dry contacts can be monitored using the two digital inputs. These can be connected to the Whisker.BlockXD™ using a 4-conductor cable. External connection is made via a 4-conductor cable. Color Black Yellow Brown Red Description GND DIN1 DIN2 NA 1|Page ™ - Whisker.IO and Whisker.BlockXD™ are trademarks of Digital Six Laboratories LLC, All Rights Reserved www.d6labs.com 1 (844) 365-8647 tel sales@d6labs.com Mechanical Electrical Specification Parameter Minimum Typical Battery life – Standard Pack 5 Battery life – Extended Pack 15 Maximum Units Year Operating Temp. Range (standard pack) -20 25 40 °C Operating Temp. Range (extended pack) -40 25 60 °C 1 20 Miles1 Transmission range Temperature measurement range -40 80 °C Temperature measurement accuracy -3 +3 °C Maximum periodic sample rate - - 24 Hours/sample Minimum periodic sample rate 5 - - Minutes/sample Order Information Part Number XB-900-0000-IS XB-900-0000-IE XB-900-0000-ES XB-900-0000-EE XB-868-0000-IS XB-868-0000-IE XB-868-0000-ES XB-868-0000-EE Description 902-928MHz Basic Whisker.BlockXD with internal antenna and standard battery pack 902-928MHz Basic Whisker.BlockXD with internal antenna and extended battery pack 902-928MHz Basic Whisker.BlockXD with external antenna and standard battery pack 902-928MHz Basic Whisker.BlockXD with external antenna and extended battery pack 868MHz Basic Whisker.BlockXD with internal antenna and standard battery pack 868MHz Basic Whisker.BlockXD with internal antenna and extended battery pack 868MHz Basic Whisker.BlockXD with external antenna and standard battery pack 868MHz Basic Whisker.BlockXD with external antenna and extended battery pack © 2017 Digital Six Laboratories Inc 2|Page ™ - Whisker.IO and Whisker.BlockXD™ are trademarks of Digital Six Laboratories LLC, All Rights Reserved www.d6labs.com 1 (844) 365-8647 tel sales@d6labs.com
XD-900-0000-IE 价格&库存
很抱歉,暂时无法提供与“XD-900-0000-IE”相匹配的价格&库存,您可以联系我们找货
