D6 Labs™
Engineered IoT Solutions
SS1-1-900-U
Universal Soap Dispenser Sensor
General Description
Internal Channels
The Universal Soap Dispenser Sensor is an IOT enabled device that is
mounted adjacent to any hand soap dispenser and counts the
number of times soap is dispensed by sensing the presence of hands
moving to and away from the soap dispenser.
This device is configured with two (2) internal channels:
Battery Voltage
The dispenser communicates to the cloud platform through our
SmartHub family of cloud connected IOT hubs. It periodically
communicates a message to the SmartHub indicating the battery
voltage and the count of dispenses since it first began operation.
This information can be used as a means of determining how much
product has been dispensed since the last refill or to determine use
frequency and time of day patterns to ensure hand wash policy
compliance.
Dispenser Count
Mounting
The Universal Soap Dispenser is mounted next to the device such
that the infra-red sensor is pointed toward the area where a hand
would be placed to acquire soap. The device should be mounted
between 3 to 15 centimeters from the soap dispensing area. Note:
the Universal Hand Dispenser must be mounted within range of a
Smart.Hub for it's reading to be passed through the Cloud platform,
and viewed in the Whisker Web Portal.
The long range, exceptional battery life and reliability make it the
perfect choice for organizations looking for insight into the hygiene
practices.
Power
The Universal Soap Dispenser is powered internally using a 3.7V,
5.2A-H LiThCl battery pack that should give 10+ years of service life
before a battery change is required, assuming a 5 minute average
dispense period.
Electrical Specifications
Parameter
Battery Life—Standard Pack
Operating Temp. Range
Transmission Range
Frequency Range
Sensor Sample Rate
Minimum
Typical
10
-4°C
Maximum
+85°C
0.8 – 1.6
902
928
5
Units
Years
Degrees Celsius
kilometers1
MHz
Minutes
1) Outdoors, line of sight, unobstructed, antenna elevation 10 feet
Order Information
Part Number
SS1-1-900-U
www.d6labs.com
sales@d6labs.com
Description
Universal Soap Dispenser Sensor , 900MHz, battery powered, int. antenna
© Copyright 2019 All Right Reserved
Page 1
1-844-365-8647
很抱歉,暂时无法提供与“SS-1-900-U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1266.346341+163.75615
