WB1-9-10-A5NNNNNN-0000-LR
    DIGITALSIXLABS
    温度,外部 0-5V 模拟输入 传感器 电压,900MHz 输出
WB1-9-10-A5NNNNNN-0000-LR 数据手册
D6 Labs™ Engineered IoT Solutions WB1-9-00-A5NNNNNN-0000-LR Whisker.Block®, 0-5V Analog General Description Internal Channels Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They can be configured for battery or external power. When powered from internal batteries, the sensors can operate for 10 or more years, depending on the sensors use and configuration. Each sensor is housed in a durable, IP67 enclosure that supports a variety of mounting methods. External sensors are connected via one or two 4-pin M8 style waterproof connectors, depending on how many external channels are configured. The long range, exceptional battery life, and flexible I/O configurations of the Whisker.Block® make it the perfect choice for nearly any IoT application. This Whisker.Block® is configured with two (2) internal channels: Battery Voltage Ambient Temperature External Connections This Whisker.Block® is configured with one (1) external channels: Power This Whisker.Block® is powered internally using a 3.7V, 5.2A-H LiThCl battery pack that should give 10+ years of service life before a battery change is required, assuming a 5 minute update period. Range They come in a variety of configurations with multiple external channels for various analog and digital inputs.In an unobstructed, outdoor line-of-site environment, the sensor should be able to communicate for more than 0.8 kilometers assuming a receiving antenna elevation of 3.0 meters. If the receiving antenna is raised to 6.1 meters or more, the range should increase to more than 1.6 kilometers. When used in environments where line of sight cannot be obtained or where there are many reflective obstacles in the transmission path, the range will degrade due to multi-path fading. It is impossible to predict the transmission range of a Whisker.Block® in any specific situation, so we do encourage users to take advantage of our site survey tools to ensure coverage exists anywhere a sensor is to be deployed. For more information on site survey techniques, see application note . www.d6labs.com sales@d6labs.com Con 2: Not used Connector 1 1 1 1 Pin 1 2 3 4 © Copyright 2019 All Right Reserved Function Vout Channel 1 Not used Ground Con 1 (Right) Description Switched output voltage 0-5V sensor input Not used Circuit ground Page 1 1-844-365-8647 Mechanical Electrical Specifications Parameter Battery Life—Standard Pack Operating Temp. Range Transmission Range Frequency Range Internal Temperature Measurement Range Internal Temperature Measurement Accuracy Sensor Sample Rate Analog Input Sensor Voltage supply Sensor Supply Current Minimum N/A -40 Typical 10 Maximum 20 +85 0.8-1.6 902 -40 -1 928 +85 1 5 0 5 18 20 Units Years Degrees Celsius kilometers1 MHz Degrees Celsius Degrees Celsius Minutes VDC VDC mA 1) Outdoors, line of sight, unobstructed, antenna elevation 3 meters Order Information Part Number WB1-9-00-A5NNNNNN-0000-LR www.d6labs.com sales@d6labs.com Description 900MHz, battery powered, int. antenna, int. temperature, ext. 0-5V analog input qty. (1) © Copyright 2019 All Right Reserved Page 2 1-844-365-8647
物料型号:WB1-9-00-A5NNNNNN-0000-LR
器件简介:Whisker.Blocks®是长距离无线传感器,有多种输入/输出和电源配置。采用专有的长距离无线通信技术,确保可靠和强大的操作。
引脚分配:该Whisker.Block®配置有一个外部通道,引脚功能如下: - 1号引脚:Vout,切换输出电压 - 2号引脚:Channel1,0-5V传感器输入 - 3号引脚:未使用 - 4号引脚:地,电路地
参数特性: - 电池寿命:标准电池组可使用10年 - 工作温度范围:-40°C至+85°C - 传输范围:0.8至1.6公里,具体取决于接收天线的高度 - 频率范围:902至928MHz - 内部温度测量范围:-40°C至+85°C - 内部温度测量精度:-1°C至1°C - 传感器采样率:5分钟 - 模拟输入:0至5VDC - 传感器电源电压:18VDC - 传感器供电电流:20mA
功能详解:该传感器可配置为电池或外部电源供电。内部使用3.7V,5.2Ah的LiThCl电池组,预计在5分钟更新周期的假设下,可使用10年以上。
应用信息:长距离、出色的电池寿命和灵活的I/O配置使其成为几乎所有物联网应用的理想选择。
封装信息:传感器安装在耐用的IP67外壳中,支持多种安装方式。外部传感器通过一个或两个4针M8型防水连接器连接。
WB1-9-10-A5NNNNNN-0000-LR 价格&库存
很抱歉,暂时无法提供与“WB1-9-10-A5NNNNNN-0000-LR”相匹配的价格&库存,您可以联系我们找货
