WB1-9-00-TRTRNNNN-0000-LR
    DIGITALSIXLABS
    WHISKER BLOCK US IT 2TR
WB1-9-00-TRTRNNNN-0000-LR 数据手册
D6 Labs™ Engineered IoT Solutions WB1-9-00-TRTRNNNN-0000-LR Whisker.Block®, Int. Temp & Dual 10KO Thermistor Input General Description Internal Channels Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They can be configured for battery or external power. When powered from internal batteries, the sensors can operate for 10 or more years, depending on the sensors use and configuration. Each sensor is housed in a durable, IP67 enclosure that supports a variety of mounting methods. External sensors are connected via one or two 4-pin M8 style waterproof connectors, depending on how many external channels are configured. The long range, exceptional battery life, and flexible I/O configurations of the Whisker.Block® make it the perfect choice for nearly any IoT application. This Whisker.Block® is configured with two (2) internal channels: Battery Voltage Ambient Temperature External Connections This Whisker.Block® is configured with two (2) external channels: Power This Whisker.Block® is powered internally using a 3.7V, 5.2A-H LiThCl battery pack that should give 10+ years of service life before a battery change is required, assuming a 5 minute update period. Range They come in a variety of configurations with multiple external channels for various analog and digital inputs.In an unobstructed, outdoor line-of-site environment, the sensor should be able to communicate for more than 0.8 kilometers assuming a receiving antenna elevation of 3.0 meters. If the receiving antenna is raised to 6.1 meters or more, the range should increase to more than 1.6 kilometers. When used in environments where line of sight cannot be obtained or where there are many reflective obstacles in the transmission path, the range will degrade due to multi-path fading. It is impossible to predict the transmission range of a Whisker.Block® in any specific situation, so we do encourage users to take advantage of our site survey tools to ensure coverage exists anywhere a sensor is to be deployed. For more information on site survey techniques, see application note . www.d6labs.com sales@d6labs.com Con 2: Not used Connector 1 1 1 1 Pin 1 2 3 4 © Copyright 2019 All Right Reserved Function Vout Channel 1 Channel 2 Ground Con 1 (Right) Description Switched output voltage 10K Thermister Input 10K Thermister Input Circuit ground Page 1 1-844-365-8647 Mechanical Electrical Specifications Parameter Battery Life—Standard Pack Operating Temp. Range Transmission Range Frequency Range Internal Temperature Measurement Range Internal Temperature Measurement Accuracy Sensor Sample Rate Analog input voltage range Sensor Voltage supply Sensor Supply Current Thermal Resistance2 Minimum N/A -40 Typical 10 0.8 902 -40 -1 Maximum 20 +85 >8.1 928 +85 1 5 4 20 4.096 20 10K Units Years Degrees Celsius kilometers1 MHz Degrees Celsius Degrees Celsius Minutes mA VDC mA ohms 1) Outdoors, line of sight, unobstructed, antenna elevation 3 meters 2) This Whisker.Block® is configured for external 10K thermistor(s) Order Information Part Number WB1-9-00-TRTRNNNN-0000-LR www.d6labs.com sales@d6labs.com Description 900MHz, battery powered, int. antenna, int. temperature, ext. 10K thermistor qty. (2) © Copyright 2019 All Right Reserved Page 2 1-844-365-8647
WB1-9-00-TRTRNNNN-0000-LR 价格&库存
很抱歉,暂时无法提供与“WB1-9-00-TRTRNNNN-0000-LR”相匹配的价格&库存,您可以联系我们找货
