WBP-TR-01-3F
WBP-TR-01-3F
    DIGITALSIXLABS
    热敏电阻 温度传感器 -40°C ~ 85°C 裸露引线
WBP-TR-01-3F 数据手册
D6 Labs™ Engineered IoT Solutions WBP-TR-01-3F 8cm Thermistor Temperature Probe, 91cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They come in a variety of configurations with multiple external channels for various analog and digital inputs. This external sensor is designed to work with a Whisker.Block® that is configured with an external thermistor (TR) input. When properly mounted, this sensor can detect temperatures in the range of -40°C to +85°C. The thermistor is contained within a 8cm stainless steel housing that can be used in air, food products, and most liquids. It is available with a 15cm and 91cm cable. We offer other temperatures probe configurations that can be used in a variety of applications. The WBP-TR-02-xx is a 13cm version of this probe, the WBP-TR-03-xx is designed to be mounted in HVAC ducts, and finally the WBP-TR-04-xx is a lug mounted probe that can be used on equipment such as motors. Part Number WB1-9-00-DCTRNNNN-0000-LR WB1-9-00-DCTRTRNN-0000-LR WB1-9-00-C1TRTRNN-0000-LR WB1-9-00-C2TRTRNN-0000-LR WB1-9-00-C3TRTRNN-0000-LR WB1-9-00-C4TRTRNN-0000-LR Wiring Power Power for the sensor is provided by the Whisker.Block®. Mounting Recommended Wiring: Connector Pin Sensor Wire 1 1 Red 1 2 or 3 Blue/Black Description Sensor power supply Thermister output The sensor is housed in a 6.1mm round by 8cm long stainless steel tube. It should be mounted so that the bottom half the tube is fully submerged in the medium you are monitoring. Take care not to crimp or otherwise damage the stainless steel tube as that might adversely affect proper operation or might shorten the operating life of the sensor. www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 1 1-844-365-8647
WBP-TR-01-3F 价格&库存
很抱歉,暂时无法提供与“WBP-TR-01-3F”相匹配的价格&库存,您可以联系我们找货
WBP-TR-01-3F
  • 1+442.385601+57.07139
