D6 Labs™
Engineered IoT Solutions
WBP-TR-01-6I
8cm Thermistor Temperature Probe, 15cm Cable
General Description
Compatible Whisker.Blocks®
Whisker.Blocks® are long-range, wireless sensors that come in a
variety of I/O and power configurations. These sensor blocks use our
proprietary long range wireless communication technology, ensuring
reliable and robust operation. They come in a variety of
configurations with multiple external channels for various analog
and digital inputs.
This external sensor is designed to work with a Whisker.Block® that is
configured with an external thermistor (TR) input. When properly
mounted, this sensor can detect temperatures in the range of -40°C
to +85°C.
The thermistor is contained within a 8cm stainless steel housing that
can be used in air, food products, and most liquids. It is available
with a 15cm and 91cm cable.
We offer other temperatures probe configurations that can be used
in a variety of applications. The WBP-TR-02-xx is a 13cm version of
this probe, the WBP-TR-03-xx is designed to be mounted in HVAC
ducts, and finally the WBP-TR-04-xx is a lug mounted probe that can
be used on equipment such as motors.
Part Number
WB1-9-00-DCTRNNNN-0000-LR
WB1-9-00-DCTRTRNN-0000-LR
WB1-9-00-C1TRTRNN-0000-LR
WB1-9-00-C2TRTRNN-0000-LR
WB1-9-00-C3TRTRNN-0000-LR
WB1-9-00-C4TRTRNN-0000-LR
Wiring
Power
Power for the sensor is provided by the Whisker.Block®.
Mounting
Recommended Wiring:
Connector Pin
Sensor Wire
1
1
Red
1
2 or 3 Blue/Black
Description
Sensor power supply
Thermister output
The sensor is housed in a 6.1mm round by 8cm long stainless steel
tube.
It should be mounted so that the bottom half the tube is fully
submerged in the medium you are monitoring.
Take care not to crimp or otherwise damage the stainless steel tube
as that might adversely affect proper operation or might shorten the
operating life of the sensor.
www.d6labs.com
sales@d6labs.com
© Copyright 2019 All Right Reserved
Page 1
1-844-365-8647
很抱歉,暂时无法提供与“WBP-TR-01-6I”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+382.078031+49.41308
