WBP-TR-03-3F
WBP-TR-03-3F
    DIGITALSIXLABS
    热敏电阻 温度传感器 -40°C ~ 85°C 裸露引线
WBP-TR-03-3F 数据手册
D6 Labs™ Engineered IoT Solutions WBP-TR-03-3F Thermistor Temperature Probe, Duct Mount, 91cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They come in a variety of configurations with multiple external channels for various analog and digital inputs. This external sensor is designed to work with a Whisker.Block® that is configured with an external thermistor (TR) input. When properly mounted, this sensor can detect temperatures in the range of -40°C to +85°C. The thermistor is contained within a 8cm stainless steel housing that can be used in air, food products, and most liquids. It is available with a 15cm and 91cm cable. We offer other temperatures probe configurations that can be used in a variety of applications. The WBP-TR-02-xx is a 13cm version of this probe, the WBP-TR-03-xx is designed to be mounted in HVAC ducts, and finally the WBP-TR-04-xx is a lug mounted probe that can be used on equipment such as motors. Part Number WB1-9-00-DCTRNNNN-0000-LR WB1-9-00-DCTRTRNN-0000-LR WB1-9-00-C1TRTRNN-0000-LR WB1-9-00-C2TRTRNN-0000-LR WB1-9-00-C3TRTRNN-0000-LR WB1-9-00-C4TRTRNN-0000-LR Wiring Power Power for the sensor is provided by the Whisker.Block®. Mounting Recommended Wiring: Connector Pin Sensor Wire 1 1 Red 1 2 or 3 Blue/Black Description Sensor power supply Thermister output The sensor is housed in a 20cm long tube with a top mounted flange. The flange has two 6.4mm holes for mounting to the duct. It should be mounted so that the sensor is fully inserted into the duct and is oriented so that the air will flow over the sensor as it passes through the duct. Take care not to crimp or otherwise damage the sensor as that might adversely affect proper operation or might shorten the operating life of the sensor. www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 1 1-844-365-8647
WBP-TR-03-3F
物料型号:文档中列出了多个兼容的Whisker.Blocks®型号,包括但不限于: - WB1-9-00-DCTRNNNN-0000-LR - WB1-9-00-DCTRTRNN-0000-LR - WB1-9-00-C1TRTRNN-0000-LR - WB1-9-00-C2TRTRNN-0000-LR - WB1-9-00-C3TRTRNN-0000-LR - WB1-9-00-C4TRTRNN-0000-LR
器件简介:Whisker.Blocks®是一系列长距离无线传感器,具有多种I/O和电源配置。这些传感器使用专有的长距离无线通信技术,确保可靠和稳健的操作。它们具有多种配置,带有多个外部通道,适用于各种模拟和数字输入。
引脚分配:推荐接线如下: - 1号引脚:红色线,用于传感器电源供应 - 2号或3号引脚:蓝色/黑色线,用于热敏电阻输出
参数特性:传感器设计用于与配置有外部热敏电阻(TR)输入的Whisker.Block®配合使用。在正确安装的情况下,该传感器可以检测-40°C至+85°C范围内的温度。
功能详解:传感器包含在一个8厘米长的不锈钢外壳内,可用于空气、食品产品和大多数液体中。它有15厘米和91厘米电缆的版本。
应用信息:传感器适用于空气、食品产品和大多数液体的温度检测,并且有不同版本的探头适用于不同的安装环境,如HVAC管道或设备如电机。
封装信息:传感器被封装在一个20厘米长的管内,顶部有一个安装法兰,法兰上有两个6.4毫米的孔,用于将传感器安装到管道上。安装时应确保传感器完全插入管道中,并正确定向以使空气流过传感器。
WBP-TR-03-3F 价格&库存
很抱歉,暂时无法提供与“WBP-TR-03-3F”相匹配的价格&库存,您可以联系我们找货
