WBP-US-01-3F
WBP-US-01-3F
    DIGITALSIXLABS
    超声波 接近传感器 1.181" ~ 299.213"(30mm ~ 7.6m)
WBP-US-01-3F 数据手册
D6 Labs™ Engineered IoT Solutions WBP-US-01-3F Ultrasonic Tank Level Sensor, 91cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They come in a variety of configurations with multiple external channels for various analog and digital inputs. This external sensor is designed to work with a Whisker.Block® that is configured with 0-5V Analog Input. When properly mounted, this sensor will detect tank levels from 3cm to 7.6 meters. Part Number WB1-9-00-DCNNNNNN-0000-LR WB1-9-00-DCTRNNNN-0000-LR WB1-9-00-DCTRTRNN-0000-LR WB1-9-00-DCA4NNNN-0000-LR WB1-9-00-DCA4A4NN-0000-LR WB1-9-00-DCA5NNNN-0000-LR WB1-9-00-DCA5A5NN-0000-LR Power Wiring This sensor requires 3.3V for operation. The Whisker Block power supply is 18V so a regulator to reduce the 18V supply down to 3.3V is required. Mounting This sensor is housed in a 5cm tube that is installed in the top or lid of the tank facing downward with a clear view of the liquid being measured. Mounting requires a 23.4mm hole through which the device can be mounted. Take care not to overtighten the nut. Recommended Wiring: Connector 1 1 1 www.d6labs.com sales@d6labs.com Pin 1 2 or 3 4 © Copyright 2019 All Right Reserved Sensor Wire Red Blue/Black White Description Sensor power supply 0-5V Analog In Ground Reference Page 1 1-844-365-8647
WBP-US-01-3F 价格&库存
很抱歉,暂时无法提供与“WBP-US-01-3F”相匹配的价格&库存,您可以联系我们找货
