WH1-9-00-IDNCN-N
WH1-9-00-IDNCN-N
    DIGITALSIXLABS
    ModbusTCP,ModbusRTU 网关 以太网
WH1-9-00-IDNCN-N 数据手册
D6 Labs™ Engineered IoT Solutions WH1-9-00-IDNCN-N Smart.Hub™ Industrial, Cellular Interface General Description Throughput The Smart.Hub™ Industrial is a rugged, versatile and reliable IOT gateway device for use in outdoor applications. Smart.Hub™ products are gateways used to move data from Whisker.Block® sensor blocks and end user customized Whisker.Engine™ based sensor nodes to the Whisker.io™ cloud platform. The SmartHub Industrial has versatile power options and can be configured with multiple power options including 8-24VDC, 85-240VAC and PoE. The number of devices that can be supported by this hub varies with the reporting rate of the connected devices. This is a single channel hub, which ultimately determines its limitations; with a single channel, this hub can process about 1,800 messages an hour. The following table estimates device capacity for several different update rates. Features • • • • • • Plug and play operation Ethernet & Cellular options Data buffering during loss of connectivity Supports all Whisker.io Cloud services Works with 3rd party platforms via Whisker.io Forwarding Supports two-way communication with field devices – monitor and control • Communicate with field devices over distances more than 1.6 kilometers. • Integrated CanBus, ModbusTCP and ModbusRTU (RS-485) protocol1. • Integrated Digital and Analog I/O1. • IP65 rate enclosure, wall and pole mounting • Flexible power options ? Power over Ethernet ? 8-48V DC ? 85-240VAC 1) Future feature Update Rate 5 Minutes 1 Hour 4 Hours 24 Hours This hub supports two-way communications with field devices that support the Whisker.io™ protocol. For battery powered devices, the hub will queue down-stream messages (commands) and send them to the device when it reports in at its sampling interval; therefore, the command latency is equivalent to the update rate of the device. For line powered devices, commands are sent immediately, with a latency of less than 1 second. Whisker.io Services Storage Alerting Robustness and Reliability The Smart.Hub Industrial can be configured with primary and secondary connections to the cloud through ethernet or cellular. When two connections are configured the hub will support automatic failover to the secondary connection. If all configured connections are lost, the hub will buffer messages in internal nonvolatile memory until cloud connectivity is restored. In the event of catastrophic failure, the data from the internal SD card can be recovered using a Windows based Data Recovery App. The Smart.Hub™ can be configured with battery back-up that will allow the hub to continue normal operation for up to 24 hours. If power is lost on hubs equipped with battery back-up, the hub will notify the Whisker.io cloud of the failure, allowing text and email alerts to be sent to specified contacts. www.d6labs.com sales@d6labs.com Estimated number of devices 250 1500 5000 10000 Dashboard Forwarding © Copyright 2019 All Right Reserved Devices that are configured with the storage service will persist their historic data in the Whisker.io cloud, making it available for visualization and analysis using our Whisker.io™ Portal web-based software. Rules based alerting allows a text or email to be sent when the specified condition is met and when it clears. Secure, user friendly dashboard with visualization through gauges, graphs, sensor signal strength and fuel gauges. The forwarding service allows two-way communications between Whisker.io devices and third party platforms such as Amazon, ThingLogix, etc. Page 1 1-844-365-8647 Mechanical Connectivity Options Every Whisker.io™ Hub can connect to the Internet via Ethernet. Hubs that are purchased with the Cellular option can also connect via Cellular. Installation and Setup All Whisker.io™ hubs are truly plug-and-play, requiring no provisioning or setup in the field. Simply mount the hub, connect it to power, and wait for all the status lights to come on. Once a hub is installed, it is automatically configured to work with devices within its transmission range. Order Information Part Number WH1-9-00-IDNCN-N www.d6labs.com sales@d6labs.com Description Whisker.io™, Smart.Hub™, Industrial, 900MHz, Cellular, 120VAC © Copyright 2019 All Right Reserved Page 2 1-844-365-8647
WH1-9-00-IDNCN-N 价格&库存
很抱歉,暂时无法提供与“WH1-9-00-IDNCN-N”相匹配的价格&库存,您可以联系我们找货
