D6 Labs™
Engineered IoT Solutions
WH1-9-00-PDNCN-N
Smart.Hub™ Pro, Cellular Interface
General Description
Throughput
The Smart.Hub™ Pro is a versatile and reliable IOT gateway device
for use in indoor applications. Smart.Hub™ products are gateways
used to move data from Whisker.Block® sensor blocks and end user
customized Whisker.Engine™ based sensor nodes to the
Whisker.io™ cloud platform.
The number of devices that can be supported by this hub varies with
the reporting rate of the connected devices. This is a single channel
hub, which ultimately determines its limitations; with a single
channel, this hub can process about 1,800 messages an hour. The
following table estimates device capacity for several different
update rates.
Features
Plug and play operation
Ethernet & Cellular options
Data buffering during loss of connectivity
Supports all Whisker.io Cloud services
Works with 3rd party platforms via Whisker.io Forwarding
Supports two-way communication with field devices – monitor
and control
• Communicate with field devices over distances more than 1.6
kilometers.
Robustness and Reliability
Update Rate
5 Minutes
1 Hour
4 Hours
24 Hours
This hub supports two-way communications with field devices that
support the Whisker.io™ protocol. For battery powered devices, the
hub will queue down-stream messages (commands) and send them
to the device when it reports in at its sampling interval; therefore,
the command latency is equivalent to the update rate of the device.
For line powered devices, commands are sent immediately, with a
latency of less than 1 second.
Whisker.io Services
If the hub loses connectivity to the Internet, it will buffer all
incoming messages from field devices to storage on the SD card.
When hub connectivity is restored, the messages will be sent to the
cloud for storage and forwarding. In the event of catastrophic
failure, the data on the SD card can be recovered using our Data
Recovery App (Windows).
Storage
Alerting
Dashboard
Forwarding
www.d6labs.com
sales@d6labs.com
Estimated number of devices
250
1500
5000
10000
© Copyright 2019 All Right Reserved
Devices that are configured with the storage service
will persist their historic data in the Whisker.io cloud,
making it available for visualization and analysis using
our Whisker.io™ Portal web-based software.
Rules based alerting allows a text or email to be sent
when the specified condition is met and when it
clears.
Secure, user friendly dashboard with visualization
through gauges, graphs, sensor signal strength and
fuel gauges.
The forwarding service allows two-way
communications between Whisker.io devices and
third party platforms such as Amazon, ThingLogix, etc.
Page 1
1-844-365-8647
Mechanical
Connectivity Options
Every Whisker.io™ Hub can connect to the Internet via Ethernet. Hubs that are purchased with the Cellular option can also
connect via Cellular.
Installation and Setup
All Whisker.io™ hubs are truly plug-and-play, requiring no provisioning or setup in the field. Simply mount the hub, connect it to
power, and wait for all the status lights to come on.
Once a hub is installed, it is automatically configured to work with devices within its transmission range.
Order Information
Part Number
WH1-9-00-PDNCN-N
www.d6labs.com
sales@d6labs.com
Description
Whisker.io™, Smart.Hub™, Pro, 900MHz, Cellular, 120VAC
Page 2
1-844-365-8647
很抱歉,暂时无法提供与“WH1-9-00-PDNCN-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4365.083501+564.52399
