WSK-900-0015
WSK-900-0015
    DIGITALSIXLABS
    湿度,温度 套件 4 件(4 个值 - 每个值 1 件)
WSK-900-0015 数据手册
D6 Labs™ Engineered IoT Solutions WSK-900-0015 Server Room Monitoring Kit, Cellular Interface General Description This kit contains a complete IoT sensor network. It is the ideal solution to remotely monitor a server room for temperature and moisture. It features the Smart.Hub (Pro, Cellular version) with power supply and antennas for cloud connectivity and (2) Whisker.Block® sensor modules. The first Whisker.Block® is for measuring ambient (room) temperature. The other Sensor Block has the following features: • A rope-type H20 sensor that can be laid along piping or on the floor to detect moisture. • An internal temperature sensor to measure the ambient temperature of the Whisker.Block® location. This bundle contains the following components: Quantity 1 Part Number WH1-9-00-PDNCN-N Description Smart.Hub™ Pro, Cellular Interface Whisker.io™, Smart.Hub™, Pro, 900MHz, Cellular, 120VAC 1 WB1-9-00-NNNNNNNN-0000-LR Whisker.Block®, Internal Temp 900MHz, battery powered, int. antenna, int. temperature 1 WB1-9-00-DCNNNNNN-0000-LR Whisker.Block®, Dry Contact Digital Input 900MHz, battery powered, int. antenna, int. temperature, ext. dry contact input qty. (1) 1 WBP_SC_0015_01 Sensor Cable / Rope Leak Sensor www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 1 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WH1-9-00-PDNCN-N Smart.Hub™ Pro, Cellular Interface General Description Throughput The Smart.Hub™ Pro is a versatile and reliable IOT gateway device for use in indoor applications. Smart.Hub™ products are gateways used to move data from Whisker.Block® sensor blocks and end user customized Whisker.Engine™ based sensor nodes to the Whisker.io™ cloud platform. The number of devices that can be supported by this hub varies with the reporting rate of the connected devices. This is a single channel hub, which ultimately determines its limitations; with a single channel, this hub can process about 1,800 messages an hour. The following table estimates device capacity for several different update rates. Features • • • • • • Plug and play operation Ethernet & Cellular options Data buffering during loss of connectivity Supports all Whisker.io Cloud services Works with 3rd party platforms via Whisker.io Forwarding Supports two-way communication with field devices – monitor and control • Communicate with field devices over distances more than 1.6 kilometers. Robustness and Reliability Update Rate 5 Minutes 1 Hour 4 Hours 24 Hours This hub supports two-way communications with field devices that support the Whisker.io™ protocol. For battery powered devices, the hub will queue down-stream messages (commands) and send them to the device when it reports in at its sampling interval; therefore, the command latency is equivalent to the update rate of the device. For line powered devices, commands are sent immediately, with a latency of less than 1 second. Whisker.io Services If the hub loses connectivity to the Internet, it will buffer all incoming messages from field devices to storage on the SD card. When hub connectivity is restored, the messages will be sent to the cloud for storage and forwarding. In the event of catastrophic failure, the data on the SD card can be recovered using our Data Recovery App (Windows). Storage Alerting Dashboard Forwarding www.d6labs.com sales@d6labs.com Estimated number of devices 250 1500 5000 10000 © Copyright 2019 All Right Reserved Devices that are configured with the storage service will persist their historic data in the Whisker.io cloud, making it available for visualization and analysis using our Whisker.io™ Portal web-based software. Rules based alerting allows a text or email to be sent when the specified condition is met and when it clears. Secure, user friendly dashboard with visualization through gauges, graphs, sensor signal strength and fuel gauges. The forwarding service allows two-way communications between Whisker.io devices and third party platforms such as Amazon, ThingLogix, etc. Page 2 1-844-365-8647 Mechanical Connectivity Options Every Whisker.io™ Hub can connect to the Internet via Ethernet. Hubs that are purchased with the Cellular option can also connect via Cellular. Installation and Setup All Whisker.io™ hubs are truly plug-and-play, requiring no provisioning or setup in the field. Simply mount the hub, connect it to power, and wait for all the status lights to come on. Once a hub is installed, it is automatically configured to work with devices within its transmission range. Order Information Part Number WH1-9-00-PDNCN-N www.d6labs.com sales@d6labs.com Description Whisker.io™, Smart.Hub™, Pro, 900MHz, Cellular, 120VAC © Copyright 2019 All Right Reserved Page 3 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WB1-9-00-NNNNNNNN-0000-LR Whisker.Block®, Internal Temp General Description Internal Channels Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They can be configured for battery or external power. When powered from internal batteries, the sensors can operate for 10 or more years, depending on the sensors use and configuration. Each sensor is housed in a durable, IP67 enclosure that supports a variety of mounting methods. External sensors are connected via one or two 4-pin M8 style waterproof connectors, depending on how many external channels are configured. The long range, exceptional battery life, and flexible I/O configurations of the Whisker.Block® make it the perfect choice for nearly any IoT application. This Whisker.Block® is configured with two (2) internal channels: Battery Voltage Ambient Temperature External Connections This Whisker.Block® has no configured external channels Power This Whisker.Block® is powered internally using a 3.7V, 5.2A-H LiThCl battery pack that should give 10+ years of service life before a battery change is required, assuming a 5 minute update period. Con 2: Not used Con 2: Not used Range They come in a variety of configurations with multiple external channels for various analog and digital inputs.In an unobstructed, outdoor line-of-site environment, the sensor should be able to communicate for more than 0.8 kilometers assuming a receiving antenna elevation of 3.0 meters. If the receiving antenna is raised to 6.1 meters or more, the range should increase to more than 1.6 kilometers. When used in environments where line of sight cannot be obtained or where there are many reflective obstacles in the transmission path, the range will degrade due to multi-path fading. It is impossible to predict the transmission range of a Whisker.Block® in any specific situation, so we do encourage users to take advantage of our site survey tools to ensure coverage exists anywhere a sensor is to be deployed. For more information on site survey techniques, see application note . www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 4 1-844-365-8647 Mechanical Electrical Specifications Parameter Battery Life—Standard Pack Operating Temp. Range Transmission Range Frequency Range Internal Temperature Measurement Range Internal Temperature Measurement Accuracy Sensor Sample Rate Minimum N/A -40 Typical 10 Maximum 20 +85 0.8-1.6 902 -40 -1 928 +85 1 5 Units Years Degrees Celsius kilometers1 MHz Degrees Celsius Degrees Celsius Minutes 1) Typical range: Outdoors, line of sight, unobstructed, antenna elevation 3 meters. Max range: Outdoors, line of sight, unobstructed, antenna elevation 12 meters Order Information Part Number WB1-9-00-NNNNNNNN-0000-LR www.d6labs.com sales@d6labs.com Description 900MHz, battery powered, int. antenna, int. temperature © Copyright 2019 All Right Reserved Page 5 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WB1-9-00-DCNNNNNN-0000-LR Whisker.Block®, Dry Contact Digital Input General Description Internal Channels Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They can be configured for battery or external power. When powered from internal batteries, the sensors can operate for 10 or more years, depending on the sensors use and configuration. Each sensor is housed in a durable, IP67 enclosure that supports a variety of mounting methods. External sensors are connected via one or two 4-pin M8 style waterproof connectors, depending on how many external channels are configured. The long range, exceptional battery life, and flexible I/O configurations of the Whisker.Block® make it the perfect choice for nearly any IoT application. This Whisker.Block® is configured with two (2) internal channels: Battery Voltage Ambient Temperature External Connections This Whisker.Block® is configured with one (1) external channels: Power This Whisker.Block® is powered internally using a 3.7V, 5.2A-H LiThCl battery pack that should give 10+ years of service life before a battery change is required, assuming a 5 minute update period. Range They come in a variety of configurations with multiple external channels for various analog and digital inputs.In an unobstructed, outdoor line-of-site environment, the sensor should be able to communicate for more than 0.8 kilometers assuming a receiving antenna elevation of 3.0 meters. If the receiving antenna is raised to 6.1 meters or more, the range should increase to more than 1.6 kilometers. When used in environments where line of sight cannot be obtained or where there are many reflective obstacles in the transmission path, the range will degrade due to multi-path fading. It is impossible to predict the transmission range of a Whisker.Block® in any specific situation, so we do encourage users to take advantage of our site survey tools to ensure coverage exists anywhere a sensor is to be deployed. For more information on site survey techniques, see application note . www.d6labs.com sales@d6labs.com Con 2: Not used Connector 1 1 1 1 Pin 1 2 3 4 © Copyright 2019 All Right Reserved Function Not used Channel 1 Not used Ground Con 1 (Right) Description Not used Dry Contact Input Not used Circuit ground Page 6 1-844-365-8647 Mechanical Electrical Specifications Parameter Battery Life—Standard Pack Operating Temp. Range Transmission Range Frequency Range Internal Temperature Measurement Range Internal Temperature Measurement Accuracy Sensor Sample Rate Minimum N/A -40 Typical 10 Maximum 20 +85 0.8-1.6 902 -40 -1 928 +85 1 5 Units Years Degrees Celsius kilometers1 MHz Degrees Celsius Degrees Celsius Minutes 1) Typical range: Outdoors, line of sight, unobstructed, antenna elevation 3 meters. Max range: Outdoors, line of sight, unobstructed, antenna elevation 12 meters Order Information Part Number WB1-9-00-DCNNNNNN-0000-LR www.d6labs.com sales@d6labs.com Description 900MHz, battery powered, int. antenna, int. temperature, ext. dry contact input qty. (1) © Copyright 2019 All Right Reserved Page 7 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WBP_SC_0015_01 Sensor Cable / Rope Leak Sensor General Description This cable kit contains a base Sensor Attachment Cable that is connected to the sensor block. The below listed components are shipped attach to the listed Sensor Attachment Cable as shown in the below diagram. This bundle contains the following components: Quantity 1 1 Part Number WBP-WL-02-3F Description H20 Leak Detection, 91cm Rope Sensor, 152cm Cable CBL_M8MALE26AWG_3FT_01 Sensor Attachment Cable, 91cm Cable Blue/No Marker = Channel 1, Yellow Marker = Channel 2 Wiring Diagram www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 8 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WBP-WL-02-3F H20 Leak Detection, 91cm Rope Sensor, 152cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They come in a variety of configurations with multiple external channels for various analog and digital inputs. This external sensor is designed to work with a Whisker.Block® that is configured with an external dry contact (DC) input. When properly mounted close to the floor, this sensor will detect standing water on the floor. When there is no water present, the DC channel will indicate a “low” state. When water is present, the DC channel will indicate a “high” state. Alternatively, you can use if you need to monitor pipes or hoses for leaks. That sensor is a rope-type H20 detector that can be laid along piping runs. Part Number WB1-9-00-DCNNNNNN-0000-LR WB1-9-00-DCTRNNNN-0000-LR WB1-9-00-DCTRTRNN-0000-LR WB1-9-00-DCA4NNNN-0000-LR WB1-9-00-DCA4A4NN-0000-LR WB1-9-00-DCA5NNNN-0000-LR WB1-9-00-DCA5A5NN-0000-LR Wiring Power This is a passive sensor that requires no external power. Mounting This sensor is designed to mount on a vertical surface, close to the floor that is being monitored. The height above the floor will determine how much standing water is required before the sensor provides a positive indication of water on the ground. The sensor is mounted via the hole in its body. A simple sheetrock screw is all that is needed. Ensure that the sensor has a secure and level mount. www.d6labs.com sales@d6labs.com Recommended Wiring: Connector Pin Sensor Wire 1 2 or 3 Blue/Black 1 4 White © Copyright 2019 All Right Reserved Description Dry Contact In Ground Reference Page 9 1-844-365-8647 D6 Labs™ Engineered IoT Solutions CBL_M8MALE26AWG_3FT_01 Sensor Attachment Cable, 91cm Cable General Description Compatible Whisker.Blocks® Whisker.Blocks® are long-range, wireless sensors that come in a variety of I/O and power configurations. These sensor blocks use our proprietary long range wireless communication technology, ensuring reliable and robust operation. They come in a variety of configurations with multiple external channels for various analog and digital inputs. The Sensor Attachment Cable is installed on the Whisker.Block® to provide a means to connect up to two (2) sensors to the Whisker.Block® without having to wire the sensor(s) directly to the Whisker.Block® circuit board connector. Part Number WB1-9-00-A5NNNNNN-0000-LR WB1-9-00-C1NNNNNN-0000-LR WB1-9-00-C2NNNNNN-0000-LR WB1-9-00-C3NNNNNN-0000-LR WB1-9-00-C4NNNNNN-0000-LR WB1-9-00-C1TRTRNN-0000-LR WB1-9-00-C2TRTRNN-0000-LR WB1-9-00-C3TRTRNN-0000-LR WB1-9-00-C4TRTRNN-0000-LR WB1-9-00-C2TRTRNN-0000-LR WB1-9-00-DCNNNNNN-0000-LR WB1-9-00-TRNNNNNN-0000-LR WB1-9-00-TRTRNNNN-0000-LR Mounting The Sensor Attachment Cable comes attached to the Whisker.Block®. In some cases, the sensors must be connected to the Sensor Attachment Cable using the wiring configuration shown on the sensor data sheet. www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 10 1-844-365-8647
WSK-900-0015 价格&库存
很抱歉,暂时无法提供与“WSK-900-0015”相匹配的价格&库存,您可以联系我们找货
WSK-900-0015
  • 1+6614.116991+855.38517
库存:5
