WSK-900-0026
WSK-900-0026
    DIGITALSIXLABS
    无线物联网传感器套件 套件 2 件(2 个值 - 每个值 1 件)
WSK-900-0026 数据手册
D6 Labs™ Engineered IoT Solutions WSK-900-0026 Hand Wash Mon. Kit, Smart, Ethernet Interface General Description This kit contains a complete solution for monitoring one handwashing station. It features the Smart.Hub (Pro, Ethernet version) with power supply and antennas for cloud connectivity and (1) hand-soap sensor. If this kit is designated as "Universal" then the sensor device will be a unit that installs next to a soap dispenser to pick up when hands enter and leave the soap well area. If this kit is designated as "Smart" then the kit includes a hand-soap dispenser with a Whisker.io™ device installed in the dispenser to count uses. This bundle contains the following components: Quantity 1 1 Part Number WH1-9-00-PDNEN-N Description Smart.Hub™ Pro, Ethernet Interface Whisker.io™, Smart.Hub™, Pro, 900MHz, Ethernet, 120VAC SS1-1-900-1 Smart Soap Dispenser Smart Soap Dispenser, 900MHz, battery powered, int. antenna www.d6labs.com sales@d6labs.com © Copyright 2019 All Right Reserved Page 1 1-844-365-8647 D6 Labs™ Engineered IoT Solutions WH1-9-00-PDNEN-N Smart.Hub™ Pro, Ethernet Interface General Description Throughput The Smart.Hub™ Pro is a versatile and reliable IOT gateway device for use in indoor applications. Smart.Hub™ products are gateways used to move data from Whisker.Block® sensor blocks and end user customized Whisker.Engine™ based sensor nodes to the Whisker.io™ cloud platform. The number of devices that can be supported by this hub varies with the reporting rate of the connected devices. This is a single channel hub, which ultimately determines its limitations; with a single channel, this hub can process about 1,800 messages an hour. The following table estimates device capacity for several different update rates. Features • • • • • • Plug and play operation Ethernet & Cellular options Data buffering during loss of connectivity Supports all Whisker.io Cloud services Works with 3rd party platforms via Whisker.io Forwarding Supports two-way communication with field devices – monitor and control • Communicate with field devices over distances more than 1.6 kilometers. Robustness and Reliability Update Rate 5 Minutes 1 Hour 4 Hours 24 Hours This hub supports two-way communications with field devices that support the Whisker.io™ protocol. For battery powered devices, the hub will queue down-stream messages (commands) and send them to the device when it reports in at its sampling interval; therefore, the command latency is equivalent to the update rate of the device. For line powered devices, commands are sent immediately, with a latency of less than 1 second. Whisker.io Services If the hub loses connectivity to the Internet, it will buffer all incoming messages from field devices to storage on the SD card. When hub connectivity is restored, the messages will be sent to the cloud for storage and forwarding. In the event of catastrophic failure, the data on the SD card can be recovered using our Data Recovery App (Windows). Storage Alerting Dashboard Forwarding www.d6labs.com sales@d6labs.com Estimated number of devices 250 1500 5000 10000 © Copyright 2019 All Right Reserved Devices that are configured with the storage service will persist their historic data in the Whisker.io cloud, making it available for visualization and analysis using our Whisker.io™ Portal web-based software. Rules based alerting allows a text or email to be sent when the specified condition is met and when it clears. Secure, user friendly dashboard with visualization through gauges, graphs, sensor signal strength and fuel gauges. The forwarding service allows two-way communications between Whisker.io devices and third party platforms such as Amazon, ThingLogix, etc. Page 2 1-844-365-8647 Mechanical Connectivity Options Every Whisker.io™ Hub can connect to the Internet via Ethernet. Hubs that are purchased with the Cellular option can also connect via Cellular. Installation and Setup All Whisker.io™ hubs are truly plug-and-play, requiring no provisioning or setup in the field. Simply mount the hub, connect it to power, and wait for all the status lights to come on. Once a hub is installed, it is automatically configured to work with devices within its transmission range. Order Information Part Number WH1-9-00-PDNEN-N www.d6labs.com sales@d6labs.com Description Whisker.io™, Smart.Hub™, Pro, 900MHz, Ethernet, 120VAC © Copyright 2019 All Right Reserved Page 3 1-844-365-8647 D6 Labs™ Engineered IoT Solutions SS1-1-900-1 Smart Soap Dispenser General Description Internal Channels The Smart Soap Dispenser is an IOT enabled device that comes embedded with our proprietary long-range communication technology ensuring reliable and robust operation. This device is configured with two (2) internal channels: Battery Voltage The dispenser communicates to the cloud platform through our SmartHub family of cloud connected IOT hubs. It periodically communicates a message to the SmartHub indicating the battery voltage and the count of dispenses since it first began operation. This information can be used as a means of determining how much product has been dispensed since the last refill or to determine use frequency and time of day patterns to ensure hand wash policy compliance. Dispenser Count Mounting The Smart Soap Dispenser comes with the wireless IoT kit preinstalled. Mount the Soap Dispenser to the wall, or another preferred location, insert the soap per the manufacturer's instructions, and begin using the device. Note: the Smart Hand Dispenser must be mounted within range of a Smart.Hub for it's reading to be passed through the Cloud platform, and viewed in the Whisker Web Portal. The long range, exceptional battery life and reliability make it the perfect choice for organizations looking for insight into the hygiene practices. Power The Smart Soap Dispenser is powered internally using a 3.7V, 5.2A-H LiThCl battery pack that should give 10+ years of service life before a battery change is required, assuming a 5 minute average dispense period. Electrical Specifications Parameter Battery Life—Standard Pack Operating Temp. Range Transmission Range Frequency Range Sensor Sample Rate Minimum Typical 10 -4°C Maximum 20 +85°C 0.8 – 1.6 902 928 5 Units Years Degrees Celsius kilometers1 MHz Minutes 1) Outdoors, line of sight, unobstructed, antenna elevation 10 feet Order Information Part Number SS1-1-900-1 www.d6labs.com sales@d6labs.com Description Smart Soap Dispenser, 900MHz, battery powered, int. antenna © Copyright 2019 All Right Reserved Page 4 1-844-365-8647
WSK-900-0026 价格&库存
很抱歉,暂时无法提供与“WSK-900-0026”相匹配的价格&库存,您可以联系我们找货
WSK-900-0026
  • 1+2860.650041+371.81475
库存:5
