50-3332-WH-KIT
50-3332-WH-KIT
    DATACOMM
    CABLE ORGANIZER KIT - WHITE
50-3332-WH-KIT 数据手册
Flat Panel TV Cable Organizer Kits Small & Medium 50-3331-WH-KIT & 50-3332-WH-KIT 50-3331-WH-KIT (Small) 50-3332-WH-KIT (Medium) Use DataComm Electronics’ new Flat Panel TV Cable Organizer Kits to install and hide unwanted audio/video (A/V) cables behind your flat panel TV, your amplifier or other audio/video devices. These kits bring a clean, professional image to your at-home installation. Determine the location of your flat panel TV, amplifier or audio/video device. Cut a hole in the wall and install the low voltage mounting bracket. Then simply pull your cables through the low voltage mounting bracket and then through the recessed cable plate. Insert the recessed cable plate into your installed mounting bracket and secure with the included screws. See diagrams below. The Flat Panel TV Cable Organizer Kits come with simple instructions for a quick and easy installation. National Electrical Code (NEC) does not allow the installation of the TV power cord or an extension cord behind the wall. Front View Back View U.S. Patent Numbers D553475, D554475 and 7390964 RoHS Compliant 3026001 DataComm Electronics 6349 Peachtree Street Norcross, GA 30071-1725 888.223.7977 770.662.8205 www.datacommcableorganizer.com
50-3332-WH-KIT 价格&库存
很抱歉,暂时无法提供与“50-3332-WH-KIT”相匹配的价格&库存,您可以联系我们找货
