FG11-4KG.160.84
FG11-4KG.160.84
    DAVIESMOLDING
    抽屉型 手柄 聚酰胺 螺钉孔,背面
FG11-4KG.160.84 数据手册
Typ FG 1 Handle Series FG11 Manageable functional handle. 2 Material and surface: Polyamide PA 6, black with fine structure. Function elements: Type 1: Flat push button with red or green LED. Type 2: Raised push button with red or green LED (convenient in case of a longer duration of activation). Connection A Connection A: 8-pin connector at the mounting surface of the handle. Coupling with 10 m ready made cable available as accessories. Connection B: The 5 m connection cable leading out of the mounting surface of the handle shank. B Protection class: IP 65 (for version A with screwed coupling). Connection A Plug B Cable A Order no. Order no. green 160 FG11-3SG.160.84 FG11-3KG.160.84 red 160 FG11-3SR.160.84 FG11-3KR.160.84 green 160 FG11-4SG.160.84 FG11-4KG.160.84 red 160 FG11-4SR.160.84 FG11-4KR.160.84 Typ 1 2 Handle accessories Coupling with cable 8-pole (M12 x 1) L 10 m www.daviesmolding.com Order no. FZ-KS.G08.10 R3 1 ø 26 14 10 40 max. 70 66 FG M6 17 160 26 Plug 8-pole, M12 x 1 182 Technical data FG11 WH(1) Push button, LED (1 NC + 1 NO contact) BN(2) LED RD(8) GY(5) GN(3) 24 V AC/DC max. 1 A Push button Operating voltage LED YE(4) 24 V DC (12 V DC optional) Connection type 8-pole, M12 x 1 RD (8) BN (2) WH (1) GN (3) Connector assignment (Plug side view) BU (7) PK (6) YE (4) GY (5) 160 17 Door solenoid tumbler see page 304–305. Mounting cutout ø 19 All dimensions in mm. ø7 www.daviesmolding.com
FG11-4KG.160.84 价格&库存
很抱歉,暂时无法提供与“FG11-4KG.160.84”相匹配的价格&库存,您可以联系我们找货
FG11-4KG.160.84
  • 1+2377.650331+307.49484
  • 5+2055.455925+265.82634
