FG13-LH15.B700.S11
FG13-LH15.B700.S11
    DAVIESMOLDING
    FUNCTIONAL HANDLE ALUMINUM/ NYLO
FG13-LH15.B700.S11 数据手册
D E L FG Handle Series FG13-LH Functional handle with a handle ledge illuminatable over a large area. The LED colours red, yellow and green can be used to display the current operating status of the machine for example. 86 20 36 102 80 45 85 Plug 12-pole, M12x1 M10 75 700 19,5 39 11 Material and surface: Handle shanks made of glass ball blasted aluminium (AlMgSi 0.5). Anodized in black. Handle ledge made of extruded hollow aluminium section AlMgSi 0.5; glass ball blasted and anodized in natural colour. Illuminatable plastic insert made of extruded, translucent PMMA. Push button 1 Push button 2 439 499 739 764 Design features: Pleasant feel thanks to the generously rounded handle ledge bottom. Function elements: Two push buttons, as NO contacts. Type FG13-LH15 additionally with emergency stop (two NC contacts). FG13-LH12 with 2 push buttons FG13-LH15 without emergency stop with emergency stop Connection A: 12-pole connector in the mounting surface of the handle shank. Coupling with 10 m readymade cable available as accessory. Connection Order no. Order no. A Plug FG13-LH12.A700.S11 FG13-LH15.A700.S11 B Cable FG13-LH12.B700.S11 FG13-LH15.B700.S11 Connection B: 5 m connection cable leading out of the mounting surface of the handle shank. Other handle lengths on request Protection class: IP 65 with coupling screwed on. Special designs: Other handle lengths and switching element assignments, as well as white handle ledge lighting on request. www.daviesmolding.com Typ FG13-LH15 Technical data Typ FG13-LH12 FG13-LH15 GY(8) Emergency stop (2 NC contact) GY/PK(11) FG without VT(10) RD/BU(12) BN(1) Push button 1 (1 NO contact) BU(2) WH(3) Push button 2 (1 NO contact) PK(5) LED board RD(9) YE(6) GN(4) 1–42 V AC/DC 100 mA – Emergency stop LED grün / green LED rot / red LED gelb / yellow BK(7) 24 V AC/DC max. 1 A Push button 24 V DC (12 V DC optional) Operating voltage LED 12-pole M12x1 Connection type BU (2) VT (10) BN (1) RD (9) WH (3) RD/BU (12) GY/PK (11) GY (8) GN (4) PK (5) YE (6) BK (7) Connector assignment (Plug side view) A 45 Mounting cutout ø 11 ø 11 ø 19 Handle accessories 10 m cable welded to coupling Order no. . Order no. 12-pole (M12 x 1) FZ-KS.G12.10 FZ-KS.W12.10 All dimensions in mm. www.daviesmolding.com
FG13-LH15.B700.S11 价格&库存
很抱歉,暂时无法提供与“FG13-LH15.B700.S11”相匹配的价格&库存,您可以联系我们找货
