FG4-LH10.375.11
FG4-LH10.375.11
    DAVIESMOLDING
    抽屉型 手柄 聚酰胺 螺钉孔,背面
FG4-LH10.375.11 数据手册
D E L FG Handle Series FG4-LH Functional handle with a three-coloured illuminatable handle ledge. The LED colours red, yellow and green can be used to display the current operating status of the machine for example. Material and surface: Handle shanks made of glass ball reinforced polyamide PA 6, black, similar to RAL 9005, semi-matte with a fine-grain structure. Threaded bushes made of brass. Handle ledge made of extruded aluminium AlMgSi 0.5; glass ball blasted and anodized in natural colour. Illuminatable plastic insert made of translucent PMMA. Typ FG4-LH10 Function elements: One push button, as a changeover contact. Connection: 5 m connection cable leading out of the mounting surface of the handle shank. Version with an 8-pole connector on request. Protection class: IP 65. Note: Other handle lengths and switching element assignments, as well as white handle ledge lighting on request. Connection Typ FG4-LH11 Typ MS-02 Counter-handle without any electrical function elements, see page 33. A* L 375 435 FG4-LH10 without push button, with LED-illumination FG4-LH11 with push button and with LED-illumination Order no. Order no. FG4-LH10.375.11 FG4-LH11.375.11 * Other handle lengths on request www.daviesmolding.com FG 8 61 60 20 Push button M6 17 Cable ø6 37 375 20 28 30 55 285 325 435 Technical data FG4-LH10 FG4-LH11 without push button with push button Typ WH PK Push button (1 change-over contact) without BN RD Push button Operating voltage LED YE LED grün / green LED board LED gelb / yellow LED rot / red GY GN 24 V AC/DC max. 1 A - 24 V DC (12 V DC optional) cable 8-pole Connection type ø7 ø7 Mounting cutout 17 All dimensions in mm. A www.daviesmolding.com
FG4-LH10.375.11 价格&库存
很抱歉,暂时无法提供与“FG4-LH10.375.11”相匹配的价格&库存,您可以联系我们找货
