ZH
Solenoid Tumbler ZH
Note:
Interlocks in other contact
variations and further actuators
on request.
13
32
44
6
15
8
90
6
Actuator
opening
12
178
6
Cable junction
6
5,5
35
29
7
Manual unlocking
30
Manual
unlocking
116
56
Actuator opening
30
72
Cable junction
M20
22
22,5
29,5
12
6
130
17,5 23,5
Movable actuators
ZH-01
ZH-02
48
6,5
57,5
8,5
32
25
15°
15°
3
15°
16
40
R min
16,5
60
. 95
R min
44
. 350
15°
13,5
Typ
ZH-01
Components
Modes of interlock
Solenoid tumbler
Power to unlock
Arbeitsstromprinzip
Power to lock
ZH-02
Solenoid tumbler
Power to unlock
Power to lock
Actuator
Order no.
ZH-01.R01.01
ZH-01.A01.01
ZH-01.000.02
Actuator
www.daviesmolding.com
2,3
6
72
38
For power to lock, the mode of
operation is reserved.
Actuator opening
11
In the case of power to unlock,
the latching bolt prevents the
actuator from being pulled out
by spring pressure. When the
deinterlocking coil is energized,
the interlock is removed.
The guarding device can be
opened.
26
6
ZH-02
39
Power to unlock/
Power to lock:
Two variations of interlocking are
offered.
ZH-01
8
Design and mode
of operation:
On the solenoid tumbler, the
switching element with interlock
is not physically connected to
the actuator, but functionally
separated or brought together
on opening or closing of the
door. Interlocking is carried out
by a latching bolt, which
prevents the actuator from being
pulled out of the interlock.
By opening and closing the door,
switching contacts in the
interlock are positively operated.
Altogether states like door
open/closed or door locked/
unlocked can be found out over
these switching contacts.
Solonoid tumbler
ø 5,5
The solenoid tumbler ZH is,
in combination with the functional handles on page 268 to 303
a electromechanical locking system for pushable and revolving
doors.
ZH-02.R01.01
ZH-02.A01.01
ZH-02.000.02
Technical data
Typ
ZH-01
ZH-02
Standards:
IEC/EN 60947-5-1, BG-GS-ET-19,
IEC 60947-5-1
IEC 60947-5-1
Enclosure:
glass fibre reinforced thermoplastic
Actuator and locking bolt:
stainless steel 1.4301
Zinc plated steel / zinc diecast, chromated
Contact material:
Silver
Silver
IP 67
IP 67
Termination:
Screw clamps
Screw clamps
Cable section:
max. 1.5 mm2 (incl. Conductor ferrules) max. 1.5 mm2 (incl. Conductor ferrules)
Protection class:
4 x M16 x 1,5
2 x M20 x 1,5
4 kV
2,5 kV
250 V
250 V
10 A
10 A
2,5 A / 24 VDC
5 A / 24 VDC
24 VAC/DC
24 VDC
- 25°C......+ 60°C
0°C......+ 50°C
2000 N
1750 N
Actuating head:
3 Actuator openings
Can be repositioned by 4 x 90°
Manual release
for manual unlocking by
triangular key
emergency exit device and
emergency release optional available
triangular key
emergency release available optionally
ZH-01
ZH-02
Cable entry:
Rated impulse withstand voltage Uimp:
Rated insulation voltage Ui:
Thermal test current Ithe:
Rated operating current/ voltage Ie/Ue:
Rated control voltage Us:
Ambient temperature:
Holding force F max:
Modes of tumbler
Power to unlock
A1
A2
13
21
41
51 71 63
33 21
A1
34 22
A2
52 72 64
14
22
42
11
12
11
12
A1 51 71 63
Power to lock
A2
13
21
41
All dimensions in mm.
ZH
14
22
42
33 21
A1
34 22
A2
52 72 64
很抱歉,暂时无法提供与“ZH-01.000.02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3+303.613803+39.26552
