ZH-01.R01.01
ZH-01.R01.01
    DAVIESMOLDING
    开关 额定电流2.5A 工作温度-25℃~+60℃
ZH-01.R01.01 数据手册
ZH Solenoid Tumbler ZH Note: Interlocks in other contact variations and further actuators on request. 13 32 44 6 15 8 90 6 Actuator opening 12 178 6 Cable junction 6 5,5 35 29 7 Manual unlocking 30 Manual unlocking 116 56 Actuator opening 30 72 Cable junction M20 22 22,5 29,5 12 6 130 17,5 23,5 Movable actuators ZH-01 ZH-02 48 6,5 57,5 8,5 32 25 15° 15° 3 15° 16 40 R min 16,5 60 . 95 R min 44 . 350 15° 13,5 Typ ZH-01 Components Modes of interlock Solenoid tumbler Power to unlock Arbeitsstromprinzip Power to lock ZH-02 Solenoid tumbler Power to unlock Power to lock Actuator Order no. ZH-01.R01.01 ZH-01.A01.01 ZH-01.000.02 Actuator www.daviesmolding.com 2,3 6 72 38 For power to lock, the mode of operation is reserved. Actuator opening 11 In the case of power to unlock, the latching bolt prevents the actuator from being pulled out by spring pressure. When the deinterlocking coil is energized, the interlock is removed. The guarding device can be opened. 26 6 ZH-02 39 Power to unlock/ Power to lock: Two variations of interlocking are offered. ZH-01 8 Design and mode of operation: On the solenoid tumbler, the switching element with interlock is not physically connected to the actuator, but functionally separated or brought together on opening or closing of the door. Interlocking is carried out by a latching bolt, which prevents the actuator from being pulled out of the interlock. By opening and closing the door, switching contacts in the interlock are positively operated. Altogether states like door open/closed or door locked/ unlocked can be found out over these switching contacts. Solonoid tumbler ø 5,5 The solenoid tumbler ZH is, in combination with the functional handles on page 268 to 303 a electromechanical locking system for pushable and revolving doors. ZH-02.R01.01 ZH-02.A01.01 ZH-02.000.02 Technical data Typ ZH-01 ZH-02 Standards: IEC/EN 60947-5-1, BG-GS-ET-19, IEC 60947-5-1 IEC/EN 60947-5-1, BG-GS-ET-19, IEC 60947-5-1 Enclosure: glass fibre reinforced thermoplastic glass fibre reinforced thermoplastic Actuator and locking bolt: stainless steel 1.4301 Zinc plated steel / zinc diecast, chromated Contact material: Silver Silver IP 67 IP 67 Termination: Screw clamps Screw clamps Cable section: max. 1.5 mm2 (incl. Conductor ferrules) max. 1.5 mm2 (incl. Conductor ferrules) Protection class: 4 x M16 x 1,5 2 x M20 x 1,5 4 kV 2,5 kV 250 V 250 V 10 A 10 A 2,5 A / 24 VDC 5 A / 24 VDC 24 VAC/DC 24 VDC - 25°C......+ 60°C 0°C......+ 50°C 2000 N 1750 N Actuating head: 3 Actuator openings Can be repositioned by 4 x 90° Manual release for manual unlocking by triangular key emergency exit device and emergency release optional available for manual unlocking by triangular key emergency release available optionally ZH-01 ZH-02 Cable entry: Rated impulse withstand voltage Uimp: Rated insulation voltage Ui: Thermal test current Ithe: Rated operating current/ voltage Ie/Ue: Rated control voltage Us: Ambient temperature: Holding force F max: Modes of tumbler Power to unlock A1 A2 13 21 41 51 71 63 33 21 A1 34 22 A2 52 72 64 14 22 42 11 12 11 12 A1 51 71 63 Power to lock A2 13 21 41 All dimensions in mm. ZH 14 22 42 33 21 A1 34 22 A2 52 72 64 www.daviesmolding.com
ZH-01.R01.01 价格&库存
很抱歉,暂时无法提供与“ZH-01.R01.01”相匹配的价格&库存,您可以联系我们找货
