SW221408-1
SW221408-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 1 W 1.4 kHz ~ 10 kHz 顶部 矩形
SW221408-1 数据手册
4 3 2 1 Part Number: DRAWN SW221408-1 7/6/2021 CJ CHECKED 7/6/2021 P.D. Description: APPROVED Waterproof Speaker 7/6/2021 J.S. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View 13 Side View Bottom View 0.3 5.8 8.4 0.3 0.5 C C 0.3 22 16.5 IP67 Double Sided Adhesive XX X Date Code Marking "21 G" 21=2021, G=Jul. B B 90 3 Wire: UL1571, AWG#32 Black 1.3 Red A Items Specifications Conditions Sound Pressure Level 92 dB (@ 1W/10cm), Avg. Resonant Frequency 1,400 Hz Frequency Range 1,400 ~ 10,000 Hz Nominal Power 1 W Max. Power 1.2 W Impedance 8 NOTES Cone Material Mylar 1) All dimensions are in mm unless otherwise noted Mount Type Flush Mount IP Rating IP67 Storage Temperature -30 ~ +70 C Operating Temperature -20 ~ +60 C 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 7/6/2021 J.S. 2) All tolerances are 0.5 mm unless otherwise noted 3) All parts meet RoHS 3 4) Subject to change or redrawn without notice 2 1 A
SW221408-1 价格&库存
很抱歉,暂时无法提供与“SW221408-1”相匹配的价格&库存,您可以联系我们找货
