Xbee USB adapter (FTDI ready)
SKU:DFR0050
INTRODUCTION
The upgraded DFRobot Xbee USB adapter is designed for the XBee module configuration parameters to facilitate using or to
work as a FTDI writer. The new version of Xbee USB adapter is also welded with the female pin for FTDI so that users can
directly use the adapter as a FTDI program writer, such as Arduino FIO/pro/mini、lilypad Arduino and so on. It's a must-have
for interactive electronic installations and projects.
The adapter allows the PC to configure XBee / Bluetooth module and the controller / development board for wireless data
transmission via mini USB cable. You can upload your program through the wireless controller module, or conduct wireless realtime data transmission. The adapter uses a FTDI232 USB-UART converter chip to ensure stable and reliable data transmission.
FEATURES
Used for the XBee module configuration parameters
Easily connected to a PC via mini USB cable
XBee-setting support software X-CTU
Also used as a USB-TTL adapter
Voltage: +5V(USB Power)
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0050”相匹配的价格&库存,您可以联系我们找货
