DFR0089
DFR0089
    DFROBOT
    ADDRESS LED 7 SEGMENT SPI
DFR0089 数据手册
    Shift out LED kit (SKU:DFR0089) Contents     1 Introduction 2 Specification 3 Pin Usage 4 Sample Code Introduction This shiftout LED Kit includes a very simple and small LED display module. It makes it possible for you to directly connect many 7-segment led modules in a chain. So you could diy a simple timer or a clock display , and many other devices that require the use of 7 segment LEDs. Specification         supply power:5V Interface: SPI Common Anode Digital Bits: 1 number of connecting:over 16 Directly connected with the interface shield Compatible with the SPI LED Module 8 Digital (Arduino Compatible) size:41x30x25mm Pin Usage Shiftout register:Digital pins 3, 8, and 9 Sample Code //Pin connected to latch pin (ST_CP) of 74HC595 const int latchPin = 8; //Pin connected to clock pin (SH_CP) of 74HC595 const int clockPin = 3; ////Pin connected to Data in (DS) of 74HC595 const int dataPin = 9; byte Tab[]={ 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff}; void setup() { //set pins to output because they are addressed in the main loop pinMode(latchPin, OUTPUT); pinMode(dataPin, OUTPUT); pinMode(clockPin, OUTPUT); Serial.begin(9600); Serial.println("reset"); for(int i = 0;i < 10; i++){ digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, Tab[i]); digitalWrite(latchPin, HIGH); delay(500); } } void loop() { if (Serial.available() > 0) { // ASCII '0' through '9' characters are // represented by the values 48 through 57. // so if the user types a number from 0 through 9 in ASCII, // you can subtract 48 to get the actual value: int bitToSet = Serial.read() - 48; // write to the shift register with the correct bit set high: digitalWrite(latchPin, LOW); // shift the bits out: shiftOut(dataPin, clockPin, MSBFIRST, Tab[bitToSet]); // turn on the output so the LEDs can light up: digitalWrite(latchPin, HIGH); } }     Powered By DFRobot © 2008-2017
DFR0089 价格&库存
很抱歉,暂时无法提供与“DFR0089”相匹配的价格&库存,您可以联系我们找货
