DFR0107
DFR0107
    DFROBOT
    INFRARED REMOTE FOR ARDUINO
DFR0107 数据手册
    IR Kit (SKU:DFR0107) Contents     1 Introduction 2 Sample Code 3 Trouble shooting 4 More Introduction IR is widely used in remoter control. With this IR receiver, the Arduino project is able to receive command from any IR remoter controller if you have the right decoder. Well, it will be also easy to make your own IR controller using IR transmitter. Sample Code // 0.1 by pmalmsten http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=117609843 4 // 0.2 by farkinga // 0.3 by farkinga - adds cool behaviors /* 0.4 by pstrobl changed the original program to use on IR Kit For Arduino Model: DFR0107 3 2 bit controller. All keypresses are sent to the serial monitor at 9600 baud. pulseIn is always HIGH. The phototransistor in the kit does not invert the signal. uses pin 13 for heartbeat debug 32 bits requires a long variable, so divided up into two 15 bit so can use integer variables use the first 15 bits of the 32 bits for remote and data stream verificati on. This code is always the same for every button press use the last 15 of the 32 bits for button press selection. This code chang es for each button. ignore the middle 2 bits, it never changes. */ #define IR_BIT_LENGTH 32 // number of bits sent by IR remote #define FirstLastBit 15 // divide 32 bits into two 15 bit chunks for inte ger variables. Ignore center two bits. they are all the same. #define BIT_1 1500 // Binary 1 threshold (Microseconds) #define BIT_0 450 // Binary 0 threshold (Microseconds) #define BIT_START 4000 // Start bit threshold (Microseconds) #define IR_PIN 2 // IR Sensor pin #define LED_PIN 13 // LED goes off when signal is received int debug = 0; ength in microseconds // flag as 1 to output raw IR pulse data stream l int output_verify = 0; // flag as 1 to print decoded verification intege rs. same number for all buttons int output_key = 0; // flag as 1 to print decoded key integers int remote_verify = 16128; // verifies first bits are 11111100000000 differe nt remotes may have different start codes void setup() { pinMode(LED_PIN, OUTPUT); pinMode(IR_PIN, INPUT); digitalWrite(LED_PIN, LOW); Serial.begin(9600); } void loop() { digitalWrite(LED_PIN, HIGH); //This shows when ready to recieve int key = get_ir_key(); digitalWrite(LED_PIN, LOW); // turn LED off while processing response do_response(key); delay(130); // 2 cycle delay to cancel duplicate keypresse s } /* wait for a keypress from the IR remote, and return the integer mapping of that key (e.g. power button on remote returns the integer 1429) */ int get_ir_key() { int pulse[IR_BIT_LENGTH]; int bits[IR_BIT_LENGTH]; do {} //Wait for a start bit while(pulseIn(IR_PIN, HIGH) < BIT_START); read_pulse(pulse); pulse_to_bits(pulse, bits); RemoteVerify(bits); return bits_to_int(bits); } /* use pulseIn to receive IR pulses from the remote. Record the length of these pulses (in ms) in an array */ void read_pulse(int pulse[]) { for (int i = 0; i < IR_BIT_LENGTH; i++) { pulse[i] = pulseIn(IR_PIN, HIGH); } } /* IR pulses encode binary "0" as a short pulse, and binary "1" as a long pulse. Given an array containing pulse lengths, convert this to an array containing binary values */ void pulse_to_bits(int pulse[], int bits[]) { if (debug) { Serial.println("-----"); } for(int i = 0; i < IR_BIT_LENGTH; i++) { if (debug) { Serial.println(pulse[i]); } if(pulse[i] > BIT_1) //is it a 1? { bits[i] = 1; } else if(pulse[i] > BIT_0) //is it a 0? { bits[i] = 0; } else //data is invalid... { Serial.println("Error"); } } } /* check returns proper first 14 check bits */ void RemoteVerify(int bits[]) { int result = 0; int seed = 1; //Convert bits to integer for(int i = 0 ; i < (FirstLastBit) ; i++) { if(bits[i] == 1) { result += seed; } seed *= 2; } if (output_verify) { Serial.print("Remote "); Serial.print(result); Serial.println(" verification code"); } if (remote_verify != result) {delay (60); get_ir_key();} //verify first grou p of bits. delay for data stream to end, then try again. } /* convert an array of binary values to a single base-10 integer */ int bits_to_int(int bits[]) { int result = 0; int seed = 1; //Convert bits to integer for(int i = (IR_BIT_LENGTH-FirstLastBit) ; i < IR_BIT_LENGTH ; i++) { if(bits[i] == 1) { result += seed; } seed *= 2; } return result; } /* respond to specific remote-control keys with different behaviors */ void do_response(int key) { if (output_key) { Serial.print("Key "); Serial.println(key); } switch (key) { case 32640: // turns on UUT power Serial.println("POWER"); break; case 32385: // FUNC/STOP turns off UUT power Serial.println("FUNC/STOP"); break; case 32130: // ||| Test Serial.println(">||"); break; case 31875: // >>| perform selected test number Serial.println(">>|"); break; case 32512: // VOL+ turns on individual test beeper Serial.println("VOL+"); break; case 31492: // VOL- turns off individual test beeper Serial.println("VOL-"); break; case 31620: // v scroll down tests Serial.println("v"); break; case 31365: // ^ scroll up tests Serial.println("^"); break; case 30982: // EQ negative tests internal setup Serial.println("EQ"); break; case 30855: // ST/REPT Positive tests Select Test and Repeat Test Serial.println("ST/REPT"); break; case 31110: // 0 Serial.println("0"); break; case 30600: // 1 Serial.println("1"); break; case 30472: // 2 Serial.println("2"); break; case 30345: // 3 Serial.println("3"); break; case 30090: // 4 Serial.println("4"); break; case 29962: // 5 Serial.println("5"); break; case 29835: // 6 Serial.println("6"); break; case 29580: // 7 Serial.println("7"); break; case 29452: // 8 Serial.println("8"); break; case 29325: // 9 Serial.println("9"); break; default: { Serial.print("Key "); Serial.print(key); Serial.println(" not programmed"); } break; } } Trouble shooting More question and cool idea, visit DFRobot Forum Powered By DFRobot © 2008-2016
DFR0107 价格&库存
很抱歉,暂时无法提供与“DFR0107”相匹配的价格&库存,您可以联系我们找货
