DFRduino Ethernet Shield V2.1 (Support Mega and
Micro SD)
SKU:DFR0125
INTRODUCTION
The DFRduino Ethernet Shield V2.1 is now released. This version of Ethernet Shield is
not only compatible with Mega 1280 and 2560, but also provides a Micro SD card slot
for reading/writing.
DFRduino Ethernet Shield V2.1 is fully compatible with Ardunio Ethernet Shield. With
the offical ethernet library, you can do exactly the same thing as the original one, but at
a more affordable price.
This Ethernet Shield provides an Arduino controller board with internet access. It is
based on the Wiznet W5100 ethernet chip. The Wiznet W5100 provides a network (IP)
stack capable of both TCP and UDP. It supports up to four simultaneous socket
connections. You can use the Ethernet library to write sketches which connect to the
internet using the shield.
You can connect the Ethernet Shield to an Arduino board using long wire-wrap headers
which extend through the shield. This keeps the pin layout intact and allows another
shield to be stacked on top.
Arduino uses digital pins 10, 11, 12, and 13 (SPI) to communicate with the W5100 on
the ethernet shield. These pins cannot be used for general i/o.
The shield provides a standard RJ45 ethernet jack.
The reset button on the shield resets both the W5100 and the Arduino board.
The shield contains a number of informational LEDs:
PWR: indicates that the board and shield are powered
LINK: indicates the presence of a network link and flashes when the shield transmits or receives
data
FULLD: indicates that the network connection is full duplex
100M: indicates the presence of a 100 Mb/s network connection (as opposed to 10 Mb/s)
RX: flashes when the shield receives data
TX: flashes when the shield sends data
COLL: flashes when network collisions are detected
Compatibility
Arduino Mega 1280/2560
Arduino UNO
Arduino Dumlinove
SHIPPING LIST
DFRduino Ethernet Shield x1
https://www.dfrobot.com/product‐455.html 8‐8‐18
很抱歉,暂时无法提供与“DFR0125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+145.773631+18.95010
