DFR0124
DFR0124
    DFROBOT
    RGB LED MODULE (UNASSEMBLED KIT)
DFR0124 数据手册
  RGB LED Module (unassembled Kit) SKU:DFR0124 INTRODUCTION This Arduino-compatible module uses three TI TLC5940 PWM LED chips to drive a 4x4 array of RGB LEDs. Each color is controlled by a different chip so you can adjust the reference resistors for the appropriate current. The TLC5940 chips are not directly connected to any Arduino pins, but a header is provided for you to make a manual connection depending on the needs of your sketch. Up to 16 of these modules can be serially connected to make a fantastic LED wall or a LED circle. It can be directly connected with Arduino via F/M cables. If you want ,you can also connect it to Interface shield through an IDC2x5 cables,and then plug the Interface shield to Arduino. NOTE: This is a Un-assembled Kit, you need soldering skill to assemble it. A tutorial is available as a reference. If you feel the assignment of the leds is not good enough, you could assign the LEDs in a custom pattern by wiring to the LED driving holes. SPECIFICATION         o o o o o Supply Power:DC 5v RGB LED: common anode IDC2x5 Serial Data Interface 4x4 array of RGB LEDs TLC5940 LED driver 16 Channels RGB LED with PWM control Size:78x45x12mm (3x1.8x0.5'') Interface: D13(SCK) TLC5940 SCLK D10(SS) TLC5940 BLANK D11(MOSI) TLC5940 SIN D9 TLC5940 XLAT D3 TLC5940 GSCLK SHIPPING LIST        RGB Module PCB board x1 RGB LEDs x16 IDC10 Interface x1 TLC5940NT chips x3 DIP28 socket x3 Jumper cap x1 20pin row needles x1        https://www.dfrobot.com/product‐459.html 8‐22‐18
DFR0124 价格&库存
很抱歉,暂时无法提供与“DFR0124”相匹配的价格&库存,您可以联系我们找货
