Mega 2560 V3.0 (Arduino Mega 2560 R3 Compatible)
SKU: DFR0191
INTRODUCTION
NEW VERSION! This is the upgraded DFRduino Mega 2560 V3.0 which is now fully compatible with Arduino Mega 2560
R3. The Arduino Mega is a microcontroller board based on the ATmega2560. It has 54 digital input/output pins (of which 14 can
be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a
power jack, an ICSP header and a reset button. It contains everything needed to support the microcontroller; Connect it to a
computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The Mega is compatible with most
shields designed for the Arduino Duemilanove, Diecimila or Uno.
One cool thing about our DFRduino microcontrollers is that the hearders with different colors are used to differentiate I/O ports
in an relatively easy way:
Red indicates Power Section
Blue indicates Analog I/O
Green indicates Digital I/O.
This kind of correspondence match exactly the same with our sensors, making it even cooler and more user-friendly.
The R3 board enjoys following new features:
Added SDA and SCL pins that are close to AREF pin and two other new pins close to RESET pin, allowing voltage adaptation
with IOREF. Our shields will be fully compatible both with the AVR boards operating @5V and Due @3.3V in future.
Improved RESET circuit
Replacing the Atmega 8U2 with Atmega 16U2 (datasheet) http://www.atmel.com/images/7799s.pdf
Version history:
V3.1 - Choose the quartz crystals resonator to improve the timer and serial accuracy. Compared with ceramic crystals, quartz crystals get
better temperature stability.
SPECIFICATION
Compatible with Arduino Mega 2560 R3
Microcontroller: ATmega2560
Operating Voltage: 5V
Input Voltage (recommended): 7 ~ 12V
Digital I/O Pins: 54 (of which 14 provide PWM output)
Analog Input Pins: 16
DC Current per I/O Pin: 40 mA
DC Current for 3.3V Pin: 50 mA
Flash Memory: 256 KB of which 8 KB used by bootloader
SRAM: 8 KB
EEPROM: 4 KB
Clock Speed: 16 MHz
The Mega is compatible with:
Mega Prototyping Shield For Arduino Mega
Mega IO Expansion Shield V2.3 For Arduino Mega
Mega-multi Expansion Shield
LCD Keypad Shield For Arduino
2A Motor Shield for Arduino
Stepper Motor Driver Shield for Arduino
Screw Shield V3 for Arduino
Xbee Shield
DFRduino Ethernet Shield (Support Mega and SD)
Relay Shield for Arduino V2.1
WIFI Shield V2.2
IO Expansion Shield For Arduino(V7)
And other arduino standard size shields...
SHIPPING LIST
DFRduino Mega 2560 V3.0 x1
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0191”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+398.986861+51.86700
- 3+352.047233+45.76500
