DFR0261
DFR0261
    DFROBOT
    CUBIEBOARD 2 KIT
DFR0261 数据手册
      Cubieboard 2 Kit SKU:DFR0261       INTRODUCTION Cubieboard2 (ARM® Cortex™‐A7 Dual‐Core), a upgrade of current cubieboard, is ready to ship now.  Cubieboard2 is based on Allwinner A20 SoC, small size , hacker friendly, extendable and very low‐cost.It  is an alternative to the Raspberry Pi or pcDuino. Compare with Raspberry Pi, it has higher performance,  SATA supported and 96 extended interface.   Compared with cubieboard,just replacing one chip(well, the most important one),cubieboard2 are  upgraded from a single core to a dual core and twice gpu performance, and even no change is needed  on the PCB. So all the base boards, accessories that works with cubieboard will also fit in with  cubieboard2.    On the software side, cubieboard2 support both android 4.2 Jelly Bean, Ubuntu 12.04 and other Linux  distributions. Android Jelly Bean improves on speed and simplicity and brings a lot of new feature.  If you plan to assemble a small computer, you can try using this small ARM platform cubieboard. It  supports Ubuntu and other Linux distributions; you could use it like an ordinary computer operation. At  the same time, the platform also supports Android 4.0 Ice Cream Sandwich system and has bulit‐in IR  sensor, can be used as "Android TV".    SPECIFICATION          CPU:ARM® Cortex™‐A7 Dual‐Core  GPU:ARM® Mali400MP2, Complies with OpenGL ES 2.0/1.1  Memory:1GB DDR3 @960M  Storage:4GB internal NAND flash, up to 64GB on uSD slot, up to 2T on 2.5 SATA disk  Power:5VDC input 2A or USB otg input  Networking:10/100 ethernet, optional wifi  USB : Two USB 2.0 HOST, one USB 2.0 OTG  Extended Interfaces: 96 extend pin interface, including I2C, SPI, RGB/LVDS, CSI/TS, FM‐IN, ADC,  CVBS, VGA, SPDIF‐OUT, R‐TP, and more  Other: One IR    SHIPPING LIST      Cubieboard 2 main board x1  DC to USB cable x1                       SATA cable(data + power) x1       Cubieboard Case x1                     Serial to USB cable x1                          Powered By DFRobot © 2008-2017
DFR0261 价格&库存
很抱歉,暂时无法提供与“DFR0261”相匹配的价格&库存,您可以联系我们找货
