DFR0287
DFR0287
    DFROBOT
    LCD12864 SHIELD FOR ARDUINO
DFR0287 数据手册
  LCD12864 Shield SKU:DFR0287    Introduction This framed LCD12864 Shield with LED backlight is compatible with most of Arduino controllers and supports English/Chinese/Picture display. With 5 analog extention pins and 8 digital pins, the LCD12864 Shield also integrates a 5-key joystick for controlling addtional functions, making it an ideal module for prototyping and interactive projects. Specification        Power supply: 3.3V Pin used: D7, D8, D9, D10, D11, D13, A0 Reset button 5 degree joystick (using Arduino Analog Pin 0) Backlit control (using Arduino Digital Pin 7) Extra 5 Analog pins & 8 Digital pins Size:60x55x20mm Pin Out Note:    Please config the driving pin using this U8GLIB_NHD_C12864 u8g(13, 11, 10, 9, 8); command.. And notice to enable this command when using the u8glib example codes also. Use "setContrast" to config the contrast as you want. We highly recommend you to setContrast to 0 to get the best display effect. "setRot90/setRot180/setRot270" functions will be helpful to rotate the display direction as you want.Recommend to use setRot180. For more useful lcd driving functions, please check u8glib userreference page. Sample Code Please download the U8glib u8glib arduino library first before compiling or uploading the sample code. #include "U8glib.h" U8GLIB_NHD_C12864 u8g(13, 11, 10, 9, 8); CS = 10, CD = 9, RST = 8 // SPI Com: SCK = 13, MOSI = 11, void draw(void) { // graphic commands to redraw the complete screen should be placed here u8g.setFont(u8g_font_unifont); //u8g.setFont(u8g_font_osb21); u8g.drawStr( 0, 20, "www.DFRobot.com"); } void setup(void) { u8g.setContrast(0); // Config the contrast to the best effect u8g.setRot180();// rotate screen, if required // set SPI backup if required //u8g.setHardwareBackup(u8g_backup_avr_spi); // assign default color value if ( u8g.getMode() == U8G_MODE_R3G3B2 ) { u8g.setColorIndex(255); // white } else if ( u8g.getMode() == U8G_MODE_GRAY2BIT ) { u8g.setColorIndex(3); // max intensity } else if ( u8g.getMode() == U8G_MODE_BW ) { u8g.setColorIndex(1); // pixel on } else if ( u8g.getMode() == U8G_MODE_HICOLOR ) { u8g.setHiColorByRGB(255,255,255); } } void loop(void) { // picture loop u8g.firstPage(); do { draw(); } while( u8g.nextPage() ); // rebuild the picture after some delay delay(500); }   https://www.dfrobot.com/wiki/index.php/LCD12864_Shield_SKU:DFR0287 6-7-17
DFR0287 价格&库存
很抱歉,暂时无法提供与“DFR0287”相匹配的价格&库存,您可以联系我们找货
