Bluno Mega 1280 (SKU:DFR0306)
Contents
1 Introduction
2 Specification
3 Pin Out
4 Supported Android Devices
5 Supported Apple Devices
6 Special Driver
7 Tutorial
7.1 More advantages
7.2 The serial port using
7.3 Sample for Bluno Mega1280 connecting to smart phones
7.4 Wireless programming via BLE
7.5 BLE firmware update of Bluno mega1280 ("AT + VERSION" to check the vertion)
Introduction
Arduino Mega Arduino is the high-end series of the Arduino controller. DFRduino Mega1280 is
based on ATmega1280 control chip as the core, with 54 digital I/O (input/output) ports (of which 14
can be used as PWM output), 16 analog input ports and 4 UART (hardware serial ports), using a 16
MHz crystal oscillator.
Embedded bootloader enables the controller to download the program directly via USB without any
other external burning device.
Multiple ways of power supply can be free to choose, including the USB power supply and universal
power adapter and battery for external power supply.
Open-sourced software and hardware platform, large interacted community, easy development
environment and strong control ability, all together making the Arduino become the most popular
electronic product development tool currently.
Specification
Microcontroller:ATmega1280
Clock frequency: 16MHZ
Transmission distance: 70m in free space
Support bluetooth remote update the Arduino program
Support bluetooth HID
Support iBeacons
Support by the AT command to debug the BLE
Support transparent transmission serial port
Support the master-salve machine switch
Support usb update BLE chip program
Working voltage:+5V
External input voltage (recommended):7V~12V DC
External input voltage (range):6V~20V DC
Digital I/O outputs: 54 (14 PWM outputs)
Analog inputs: 16
I/O current: 40mA
Flash capacity: 128KB (4k for bootloader)
Static storage capacity of SRAM: 8KB
Memory capacity of EEPROM: 4KB
Pin Out
Fig1: Bluno Mega1280 Pin Out
The figure above shows Bluno Mega1280 controller with all the ports, which includes:
Power: USB power supply or external DC2.1 power supply; automatically disconnect USB power
supply when using an external power supply; external power supply transformed as stable 5V
through an on-board DC-DC power conversion; current output capacity up to 2A, and USB power
supply 5V when the maximum output current is 500mA.
DC2.1 power input interface, voltage range: 5-23V
USB interface, power supply and communication
2 I2Cs
4 UARTs (hardware serial ports)
54 digital input/output pins (of which 14 can be used as PWM outputs)
16 analog inputs
5V and 3.3V output
A reset button
A BLE chip firmware update button
Android 4.3 and above systems equipped with Bluetooth 4.0:
Nexus 4+
MI 2s
Samsung Galaxy s4
Samsung Galaxy note 3
Recommanded Android version:
BLE Android 4.3 ROMs (Cyanogenmod Stable version)
iOS 7.0+ Devices:
iPhone 4S+
iPad 3+
iPad Mini
iPod 5th Gen
Special Driver
Bluno Mega1280 requires a special driver. Please download the Special Driver, and install it in the
Device Manager.
If you find it doesn't display Mega1280 in the Device manager, please uninstall the driver and
reinstall the correct one again.
Tutorial
More advantages
Compared with the first Bluetooth 4.0 integrated Arduino board , Bluno, Bluno Mega1280 not only
inherits the advantages of this Bluetooth 4.0 wireless communication function, but also enables more
digital and analog ports allowing bigger code storage space. That is to say, you can use Bluno
Mega1280 to make more functional DIY works. Also improvement has been done on power supply,
with the power input range widened to 5-23V. The board output current capacity has also been
greatly increased to 2A (using DC2.1 port to supply power), which is even more fortunate.It means
Bluno Mega1280 is able to connect more external sensor modules concurrently. The shield interface
is compatible with the Arduino shield interface, as it was priviously. Yes, it will undoubtly become a
powerful core board for making creative DIY works.
Bluno Mega1280 and Mega1280 have the same serial port configuration, with only adding a serial
port for Bluetooth 4.0 wireless passthrough. Bluno Mega1280 has four serial ports, allowing
concurrently connecting 4 communication modules.
Arduino language provides some functions that can be used for operating Bluno Mega1280 serial
ports. Taking Serial port 0 as an example, the operation functions are Serial.begin (), Serial.read(),
Serial.print() and Serial.println(). The other three serial port usages are the same as Serial port 0,
like that all the operations functions of Serial port 2 are serial2.begin(), serial2.read(), serial2.print()
and serial2.println().
Please refer to Sample for Bluno connecting to smart phones
Please refer to Wireless programming via BLE of Bluno
Please refer to BLE firmware update of Bluno
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0306”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+220.130421+28.47723
