DFR0357
DFR0357
    DFROBOT
    EXPANSION SHIELD X200 FOR RASPBE
DFR0357 数据手册
    Expansion Shield X200 for Raspberry Pi B+/2B/3B SKU:DFR0357   INTRODUCTION The Expansion Shield X200 is a most cost-effective shield which could apply to Raspberry Pi Model B+, Raspberry Pi 2 Model B and newest Raaspberry Pi 3 Model B. It integrates a lot of very useful functions such as RTC real time clock; audio input and output; VGA output; USB hub; WIFI; 8-way GPIO. With this shield, you can build Raspberry Pi projects more easily and save both time and cost.     SPECIFICATION                    Input Voltage: 6V to 21Vdc converted to 5V, 3A via step-down DC/DC converter to power the Raspberry Pi VGA output: HDMI to VGA converter supporting up to UXGA (1600×1200) and 1080p with 10-bit DAC Audio: 3.5mm MIC in jack 3.5mm stereo audio jack SPDIF output Audio IO connector (Microphone input and stereo audio amplifier 3.3Wx2) Wireless: WiFi (IEEE 802.11b/g/n) with external antenna IR sensor (38KHz) USB Storage: Self-powered USB hub with 3 ports Real-time clock (RTC): Based on DS3231SN with included CR2032 battery GPIO Control: 8-channel Darlington driver chip (ULN2803) allowing to control electronic circuits which require more current Misc: Power output socket Camera flex slot so camera can still be used with the expansion board attached DIP switch to remove connection from RPi’s pin header Directly connected on top of the Raspberry Pi using the board GPIO header pins No wiring nor soldering is required Duplicated the 40-pin header of the R-Pi in order to support existing expansion boards Suitable for Raspberry Pi Model B+ and Raspberry Pi 2 Model B NEW! Dimensions: 85 x 56mm(3.35 x 2.20") (Same size as Raspberry Pi) Note: When you power Raspberry Pi with the shield power resource, please don't power it again via the Micro-USB port, it will damage the board! SHIPPING LIST       X200 Raspberry Pi expansion board x1 HDMI adapter x1 USB adapter x1 2.4GHz WIFI antenna x1 nylon spacers (M3 x 20mm) x4 nylon screws (M3 x 6mm) x8                               Powered By DFRobot © 2008-2017
DFR0357 价格&库存
很抱歉,暂时无法提供与“DFR0357”相匹配的价格&库存,您可以联系我们找货
