Wireless Charging Module 5V/300mA
SKU:DFR0363
INTRODUCTION
Wireless charging uses an electromagnetic field to transfer energy between two
objects. This is usually done with a charging station. Energy is sent through an
inductive coupling to an electrical device, which can then use that energy to charge
batteries or run the device.
This is a new wireless charging module, which could provide 5V@300mA (MAX
600mA) power output. It is using the new technology "resonant magnetic coupling,
which will reduce the electricity consumption during power transmission. The
transfer efficiency could arrive at 90%. It could meet your most project requests.
5V/1A also available (Wireless Charging Module 5V/1A)
FEATURES
Stable Power Supply
Magnetic coupling resonance technique
Insulation Coil
Compact Design
SPECIFICATION
Chip on Board: XKT‐412
Operating Voltage (Input): 5V
Operating Voltage (Output): 5V@300mA (Max: 600mA)
Transmitting Terminal Size: 33±2mm(1.30")(Outer diameter)*5mm(0.20")(Inside
diameter)*1mm(0.04")(Thickness)
Receiving Terminal Size: 21±2mm(0.83")(Outer diameter)*10mm(0.39")(Inside
diameter)*0.5mm(0.02")(Thickness)
Operating Distance: 2‐10mm (0.08‐0.39")
https://www.dfrobot.com/product‐1283.html 8‐23‐18
很抱歉,暂时无法提供与“DFR0363”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+79.778491+10.37340
- 3+70.392783+9.15300
