DFR0392
DFR0392
    DFROBOT
    DFRDUINO M0 NUC123 EVAL BRD
DFR0392 数据手册
          DFRduino M0 Mainboard (Arduino Compatible)  SKU: DFR0392  Introduction DFRduino M0 is the only Arduino main board that supports 5V standard Logic level and adopts ARM Cortex-M0. [null It is unsatisfactory to make projects with most boards in the market. To be specify,] traditional Arduino UNO is lacking of pins, low-performance… Mega boards are better but too expensive; Arduino ZERO boards are not compatible with 5V power supply device. Luckily, DFRduino M0 is a great soul solves all. DFRduino M0 selects 32 bytes Nuvoton SCM (Single Chip Micyoco) of high-performance as the core. Besides built-in ARM Cortex M0 infrastructure, DFRduino M0 supports 5V Logic level, equipped with 1 USB port and 2 serial ports, providing 31 digital pins (parts AFIO) and 6 analog pins, offering more IO resources. Moreover, DFRduino M0 is compatible with Arduino Leonardo package/encapsulation and the clock speed is 72MHz. Additionally, DFRduino M0 supplies another IIS interface, supporting play &record wav files. Once put DFRduino M0 with advanced IIS chip, professional HIFI audio is available. NOTE: Different from official Arduino M0, DFRduino M0 adopts a unique chip solution which should be installed independently. It supports Windows, Linux and MAC. The default IDE version should be 1.6.0 and above, other versions should be modified according to FAQ instructions. Features        Arduino IDE Compatible 32-Bit 72MHz Cortex-M0 Supports 5V reference voltage Supports standard IIS audio interface Support USB and dual physical hardware serial port Compatible with Leonardo pin packages Support wireless programming upload code Specification                   Microcontrollers: Nuvoton NUC123ZD4AN0 (Cortex M0) Clock Speed: 72MHz Operating Voltage: 5V Recommended Input Voltage: 7-12V Limit input voltage: 6-20V Digital I/O Pins: 31 Analog input Pins: 6 External Interrupt: 4 SRAM: 20K Flash: 68K (of which 12 KB used by bootloader, 55K used by the user code area, 1K used by EEPROM) EEPROM: 1K SPI: 1 port (D14, D15, D16) IIC / I2C: 1 port (D2, D3) USB serial port: 1 (Serial) Physical serial port: 2 (Serial1, Serial2) Serial1 0 (Rx1) and 1 (Tx1) Serial2 24 (Rx2) and 25 (Tx2) Xbee interface: 1 (Serial1) Size: 68 * 53 mm/ 2.68 * 2.09 inches Weight: 30g Board Overview DFRduino M0 Mainboard (Arduino Compatible) Num 1 2 3 4 5 6 7 8 Label USB External Power Digital IO D0~D13 Digital IO D24~D31 SPI Interface Analog A0~A5 MCU Xbee Socket Description USB Power 7~12V Digital IO D0~D13 (Leonardo Compatible) Digital IO D24~D31 D14, D15, D16 (Pin Multiplexing) Analog A0~A5 (D18~D23 Multiplexing) NUC123LD4AN0 Serial1, support wireless programming PinMap DFRduino M0 Pins D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 IC pin PC4 PC5 PF2 PF3 PC0 PC3 PA13 PC2 PC3 PA14 Multiplex RXD1 TXD1 SDA SCL I2S LRCLK PWM0 PWM1 I2S DI I2S DO PWM2 Note INT2 INT3 INT0 INT1 / / / / / / D10 D11 D12 D13 D14 D15 D16 D17 D18 D19 D20 D21 D22 D23 D24 D25 D26 D27 D28 D29 D30 D31 D32 PA15 PB8 PC1 PB14 PA10 PA11 PC11 PB6 PD0 PD1 PD2 PD3 PD4 PD5 PB4 PB5 PC10 PC9 PC13 PC12 PB9 PB10 PB7 PWM3 PWM4 I2S BCLK PWM5 SPI MISO SPI SCK SPI MOSI RX LED A0 A1 A2 A3 A4 A5 RXD2 TXD2 NULL NULL NULL NULL NULL NULL TX LED / Software PWM / Software PWM / / / / / / / / / / RX2 TX2 / / / / / / /   Tutorial Requirements  Hardware DFRduino M0 x 1 Micro USB Cable x1  Software Arduino IDE (Version requirements: V1.6.X and later), Click to Download Arduino IDE from Arduino® https://www.arduino.cc/en/Main/Software%7C Setup DFRduino M0 Software Development Environment  Open Arduino IDE, File->Preferences, find Additional Boards Manager URLs, copy the below link, and paste in the blank. https://raw.githubusercontent.com/DFRobot/DFRobotDuinoBoard/master/package_dfrobot_m3_inde x.json  File->Preferences  paste url here   Click OK Open Tools->Board->Boards Manager, enter DFRduino in the search box, click Install Search “DFRduino M0” Install DFRduino M0 MainBoard Now, the development environment has been installed, you can use it like a normal Arduino board. Driver Installation  Connect M0 to your computer, and you will find an unknown device in the device manager.   Update Driver Software --> Browse my computer for driver software . Generally, this driver is located in the SDK folder C:\Users\yourUserName\AppData\Local\Arduino15\packages\nucDuino\hardware\nucDuino\1. 0.0\driver  Or you can download it here directly: Click to save. Sometime you need disable the digital signature. https://raw.githubusercontent.com/DFRobot/DFRobotDuinoBoard/master/DFRduino%20M0%20Main Board.inf Special Function Hardware Serial port x2 & USB Serial Port x1   Just like Arduino Leonardo, M0 has USB Serial Port and Hardware Serial Port. USB Serial Port Serial Hardware Serial Port 1 Serial1 Hardware Serial Port 2 Serial2 Sample Code void setup() { // put your setup code here, to run once: Serial.begin(115200); while(!Serial); Serial1.begin(115200); Serial2.begin(115200); } void loop() { // put your main code here, to run repeatedly: Serial.println("I am USB CDC Serial"); Serial1.println("I am Serial 1"); Serial2.println("I am Serial 2"); delay(1000); }  Tested Platform: Windows: win7 32bit/64bit, win8 32bit/64bit, win10 32bit Linux: ubuntu 12.04 32bit Mac book: FAQ Q1. No permission under Linux system A. Input ’‘’sudo usermod -a -G USER NAME dialout‘’‘ to add user into dialout group. Log out and log back in     For any questions, advice or cool ideas to share, please visit the DFRobot Forum.                                   https://www.dfrobot.com/wiki/index.php/DFRduino_M0_Mainboard_(Arduino_Compatible)_SKU:_DFR0392 12‐8‐17
DFR0392 价格&库存
很抱歉,暂时无法提供与“DFR0392”相匹配的价格&库存,您可以联系我们找货
