LattePanda (4G/64GB/Without win10 License) - The
Most Powerful Win10 Dev Board
SKU:DFR0419
INTRODUCTION
LattePanda is the most powerful dev board in the market. It is based on intel Atom CherryTrail chip which is able to run full
version of windows 10. It also supports Linux and Android, make it the only dev board that can run windows/linux/android.
It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you
know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on LattePanda.
LattePanda is able to install full edition of Windows 10, including powerful tools such as Visual Studio, NodeJS, Java,
Processing, and more. Using existing APIs, you can develop your own software and hardware projects on LattePanda as you
would on a normal PC - C#, Javascript, Ruby and so on.
LattePanda is also designed with an Arduino compatible co-processor, which means it can be used to control and sense the
physical world, just like an Arduino board! Whether you are a Windows developer, an IoT developer, a hardware DIY fanatic,
interactive designer, robotics whizz, or a maker, LattePanda can aid your creative process with physical computing projects!
1. This product requires a power supply of 5v@2a to work properly using a quality USB cable. An iPad power supply is ideal.
2. DO NOT USE quick charger! It will damage the board!!!
SPECIFICATION
o
o
Processor: Intel Cherry Trail Z8300 Quad Core 1.8GHz
Operation System: Full edition of Windows 10 / Linux
Ram: 4GB DDR3L
Storage Capability: 64GB
USB:
USB 3.0*1
USB 2.0*2
WiFi and Bluetooth 4.0
Co-processor: ATmega32u4
GPIO: 2 GPIOs for Intel chip 20 GPIOs for Arduino
Power: 5v/2A
Dimension: 3.46"x2.76"
Weight: 100g
SHIPPING LIST
LattePanda 2G/32GB x1
WiFi Antenna x1
Safety Precautions x1
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0419”相匹配的价格&库存,您可以联系我们找货
