DFR0430
DFR0430
    DFROBOT
    GEARMOTOR 3.5-8V MICRO METAL
DFR0430 数据手册
        Gravity: DC Micro Metal Gear Motor w/Driver For Arduino ‐ 30:1  SKU: DFR0430      INTRODUCTION An ordinary DC motor requires an H Bridge to work with a microcontroller such as an UNO. For newcomers to electronics, the process of finding the right motor driver, connecting it to the MCU and learning the relevant electronic theory can be confusing and frustrating when you just need something to work quickly. We hope that using the DC Micro Metal gear motor changes this.       The new micro DC geared motor is easy to operate ‐ using the DFRobot "Gravity" interface, you are able  to control the motor using only one control signal. Easily implement forward/reverse control and speed  control via PWM. This motor also combines the features of a DC motor and 360 degree servo. We have  also increased the stop range and reduced standby power consumption, so the current draw is less than  1mA without signal control. The Arduino Servo library supports up to 12 motors on most Arduino boards  and 48 on the Arduino Mega. More fucntion could be found on Arduino Servo page. Ideal for DIY  projects!    NOTE: The embedded control chip will consume a small amount of the input voltage, therefore the  motor voltage will be slightly reduced. The motor speed will also be slightly slower than the rated motor  speed.  SPECIFICATION              Operating voltage: 3.5V ‐ 8V  Reduction ratio: 30:1  No load current: 40mA@6V (approx)  Static current:
DFR0430 价格&库存
很抱歉,暂时无法提供与“DFR0430”相匹配的价格&库存,您可以联系我们找货
