LattePanda (2G/32GB/Without Win10 License) - The Most Powerful Win10 Dev Board
SKU:DFR0444
INTRODUCTION
This product is expected to be available at the end of December
LattePanda is a complete Windows 10 computer on a single board!
It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you
know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on LattePanda.
LattePanda comes pre-installed with a full edition of Windows 10, including powerful tools such as Visual Studio, NodeJS, Java,
Processing, and more. Using existing APIs, you can develop your own software and hardware projects on LattePanda as you
would on a normal PC - C#, Javascript, Ruby and so on. Say goodbye to your bulky laptop!
But not only can it be used as a low cost regular Windows computer! LattePanda is also designed with an Arduino compatible coprocessor, which means it can be used to control and sense the physical world, just like an Arduino board! Whether you are a
Windows developer, an IoT developer, a hardware DIY fanatic, interactive designer, robotics whizz, or a maker, LattePanda can
aid your creative process with physical computing projects!
Note:
1. This product requires a power supply of 5v@2a to work properly using a quality USB cable. An iPad power supply is ideal.
2. DO NOT USE quick charger! It will damage the board!!!
SPECIFICATION
o
o
o
Processor: Intel Cherry Trail Z8300 Quad Core 1.8GHz
Operation System: Pre-installed full edition of Windows 10
Ram: 2GB DDR3L
Storage Capability: 32GB
GPU: Intel HD Graphics, 12 EUs @200-500 Mhz, single-channel memory
One USB3.0 port and two USB 2.0 ports
WiFi and Bluetooth 4.0
Built-in Arduino Co-processor: ATmega32u4
Video output: HDMI and MIPI-DSI
Onboard touch panel overlay connector
Supports 100Mbps Ethernet
GPIO:
6 GPIOs from Cherry Trail processor
20 GPIOs from Arduino Leonardo
6 Plug and play Gravity sensor connectors
Power: 5v/2A
Dimension of board: 88 * 70 mm/ 3.46 * 2.76 inches
Packing Size: 110 * 94 * 30 mm/4.33 * 3.70 * 1.18 inches
N.W.: 55g
G.W.: 100g
SHIPPING LIST
LattePanda 2G/32GB x1
WiFi Antenna x1
Safety Precautions x1
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0444”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1266.860131+164.10270
