DFRobot CurieNano ‐ A mini Genuino/Arduino 101 Board SKU:
DFR0453
From Robot Wiki
Contents
1 Introduction
2 Specification
3 Board Overview
4 Tutorial
o 4.1 Requirements
o 4.2 Install Arduino/Genuino 101 Plug‐in
o 4.3 CurieNano Example Program
o 4.4 CurieNano Project Development
o 4.5 Onboard Electronic Compass
Introduction
The CurieNano is a small development tool based on the Intel® Curie™ module. It is easy to use
and perfectly compatible with the Genuino/Arduino 101. The small size allows it to better fit
your project's development and creation and makes it ideal for wearable tech and small
prototypes.
The Intel Curie module contains a x86 quark core and a 32bit ARC architecture core (Zephyr),
integrated Bluetooth 4.0 and 6 axis attitude sensor. The module's clock frequency is0 32MHZ
and the cross tool chain of Intel can support the development of two cores. The Intel Curie
includes dual core storage and users are able to use 196Kb Flash (total 384Kb) and 24Kb SRAM
(total 80Kb). It is more than sufficient for most development scenarios with the added bonus of
Intel's strong support network to aid your development.
Specification
Control Chip: Intel Curie
BAT Port Power Supply Voltage: 3.5V‐6.5V
5V Port Voltage: 4.5V‐5.5V
3V3 Port Voltage: 2.97V‐3.63V
Digital IO Ports: 15 (including 4 PWM pins D3, D5, D6, D9,)
Analog IO Input: 6
IO Port DC Drive Current: 20mA
Integrated Bluetooth 4.0
Integrated 6 axis accelerometer and 3 axis electronic compass on board, full inertial navigation
Onboard boost circuit can provide 1.5A@5v sensor power supply when using lithium battery
supply
Clock speed: 32Mhz
Compatible with Arduino IDE 1.6.7 or above
Bootloader: Arduino/Genuino 101
Board Overview
Function Description:
Onboard D13 LED, ERR and COM light
Onboard TI TPS61020 boost circuit
Extended D20 Digital Pin
Tutorial
CurieNano is perfectly compatible with all the features of Arduino/Genuino 101 with the bonus
of added features.
Requirements
Hardware
o CurieNano x1
o Micro USB x1
Software
o Arduino IDE V1.6.9 Click to Download Arduino IDE from Arduino®
NOTE: This is based on the Intel Curie motherboard design. When developing in Arduino
IDE you will need to add it's extension plug-in. If you have Arduino 1.6.7 IDE or above, you
can skip the reload step.
Open Arduino IDE, select "Tools" in the menu bar, click "Board" to open the board manager and
install the Intel Curie motherboard programming libraries and drivers.
In the pop-up window of the board manager find "Intel Curie Boards by Intel version...", at the
bottom left, select the latest version of the "select version", and click on install. When it is
installed successfully you will see the following image.
After the successful installation of Intel Curie Boards of plug-in and driver package, you should
find Intel Curie in the "Board" menu. You may now program for all based Curie development
board.
Note: If you want to install the driver manually, it is located in your
C:\Users\YourUserName\AppData\Local\Arduino15\packages\Intel\tools\arduino101loa
d\1.6.9+1.24\drivers folder.
Once you have successfully installed the development environment, programming the
CurieNano the same as using an Arduino. The following is a brief tutorial:
Open Arduino IDE and connect the CurieNano using a MicroUSB cable. The system should
automatically install Arduino 101 drivers and identify CurieNano COM port at the bottom right
of the window.
Open the famous "Blink" Example program. Under "Board" select Arduino 101. Under "port"
select the corresponding COM port. Finally click "upload" to upload the sample program.
If your upload was successful you should see this:
Click to view:CurieNano(Arduino/Genuino 101)Bluetooth, Accelerometer + Gyros
cope, and Real-Time Clock Libraries
Click to view:CurieNano Advanced Tutorial(Step Count,Shock detection and Hea
rt Rate Monitor,etc.)
The CurieNano is designed to be compatible with Arduino 101. Use a 3.7V lithium batterypower to use the Batt interface Curie is ideal for small prototype projects, such as wearables,
IoT Bluetooth sensor nodes and robotics projects.
HMC5883L libraries About Library installation.
Download "Arduino-HMC5883L-master.zip" and unpack it, copy the HMC5883L folder to the
Libraries folder of Arduino and then open Arduino IDE.
From "File -> Examples -> HMC5883L -> HMC5883L_compass" to open
"HMC5883L_compass.ino", select your "board" and "port" and upload to the CurieNano in the
same way you uploaded the blink sketch.
Wait five seconds after the download is complete, open the serial monitor port and set the baud
rate 9600. Rotate the CurieNano board and you should see the angle change.
For any questions/advice/cool ideas to share, please visit the DFRobot Forum or email
techsupport@dfrobot.com
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0453”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+316.654921+40.96415
