DFR0469
DFR0469
    DFROBOT
    SD2405AL 实时时钟(RTC) 时钟定时 Gravity 平台评估扩展板
DFR0469 数据手册
  Gravity: I2C SD2405 RTC Module SKU: DFR0469    Introduction We're glad to introduce a new member in Gravity family: Gravity I2C SD2405 RTC module. This is an extremely accurate I2C real-time clock (RTC) with crystal compensation, inner chargeable battery. The SD2405AL is available in industrial temperature ranges. The SD2405AL is dual power supply system. When the primary power supply goes down to an assigned value or resumes from low power, the system can switch between the primary power supply and battery automatically. Even there is no external power, it can still work for 5~8 years, 1uA ultra-low power consumption (inner battery, Ta=25°C). The SD2405AL can generates various periodic interrupt clock pulses lasting for long period (one year), and three alarm interrupts can be made by year, month, date, days of the week, hours, and minutes, seconds. It also provides a selectable 32.768KHz~1Hz clock output for an external MCU. The product incorporates a time trimming circuit that adjusts the clock with higher precision by adjusting any errors in crystal oscillator frequencies based on signals from the CPU. A 12-bytes general SRAM is implemented in the SD2405AL. Gravity SD2405 RTC can work as data logger, timer alarm clock and other time application. It is an ideal choice for timing project. Specification              Operation voltage range:3.3V~5.5V. Low-power:typical 1uA (inner battery, Ta=25°C) Timing Range: To 2099 (with leap year compensation) Accuracy ±5ppm from -40°C to +85°C. Fast (400kHz) I2C Interface(4.5~5.5V). Real-Time Clock Counts Seconds, Minutes,Hours, Day, Date, Month, and Year with Leap Year Compensation Valid Up to 2100. Time-of-Year,Month,Day,Week,Hour,Minute,Second Alarms. Programmable Square-Wave Output:32768hz,4096hz...1hz..1/16hz. Countdown timer interrupt. High precision time trimming circuit. 12-hour/24-hour time display selectable Dimension: 35.50 * 22.00(mm)/1.4 * 0.87 inches Weight: 6g Board Overview Gravity: I2C SD2405 RTC Module Num 1 2 Label Description Gravity Interface SDA: IIC Data SCL: IIC Clock GND: GND VCC: 3.3~5V XH2.54 Pins SDA: IIC Data SCL: IIC Clock GND: GND VCC: 3.3~5V INT: Interrupt Tutorial In this tutorial, you can set and read time. Requirements  Hardware DFRduino UNO (or similar) x 1 Gravity: I2C SD2405 RTC Module M-M/F-M/F-F Jumper wires  Software Arduino IDE, Click to Download Arduino IDE from Arduino® https://www.arduino.cc/en/Main/Software%7C Connection Diagram Gravity: I2C SD2405 RTC Module Arduino Connection Diagram Sample Code Please download Arduino RTC library. How to install Libraries in Arduino IDE https://github.com/DFRobot/Gravity-I2C-SD2405-RTC-Module/raw/master/GravityRtc.zip https://www.arduino.cc/en/Guide/Libraries#.UxU8mdzF9H0%7C Note: //rtc.initRtc(2017,6,19,1,12,7,0); //Set Time: 2017/June/19th/Monday/12:07:0 am. Please comment it after you have set time successfully!!!!!!! #include "GravityRtc.h" #include "Wire.h" GravityRtc rtc; //RTC Initialization void setup() { Serial.begin(9600); rtc.setup(); //rtc.initRtc(2017,6,19,1,12,7,0); :0 am //Set Time: 2017/June/19th/Monday/12:07 //Please comment it after you have set time successfully!!!!!!! } void loop() { rtc.update(); //*************************Time******************************** Serial.print(" Year = ");//year Serial.print(rtc.year); Serial.print(" Month = ");//month Serial.print(rtc.month); Serial.print(" Day = ");//day Serial.print(rtc.day); Serial.print(" Week = ");//week Serial.print(rtc.week); Serial.print(" Hour = ");//hour Serial.print(rtc.hour); Serial.print(" Minute = ");//minute Serial.print(rtc.minute); Serial.print(" Second = ");//second Serial.println(rtc.second); delay(1000); } Expected Results https://www.dfrobot.com/wiki/index.php/Gravity:_I2C_SD2405_RTC_Module_SKU:_DFR0469 7-7-17
DFR0469 价格&库存
很抱歉,暂时无法提供与“DFR0469”相匹配的价格&库存,您可以联系我们找货
DFR0469
  • 1+75.401501+9.73460
库存:109
DFR0469
库存:33
