DFR0477
DFR0477
    DFROBOT
    - RTL8195 收发器; 802.11 b/g/n(Wi-Fi,WiFi,WLAN) 2.4GHz 评估板
DFR0477 数据手册
        Realtek Ameba-RTL8195AM WiFi & NFC Module  SKU:DFR0477       INTRODUCTION Ameba-RTL8195AM is an IoT (Internet of things) microcontroller developed by Realtek. It combines an ARM-Cortex M3 MCU, Wi-Fi and NFC (Near Field Communication) in a single chip. It provides high speed connectivity interface, such as USB 2.0 host, USB 2.0 device, SDMMC HS, SDIO device and MII/RMMII interfaces. It also provides a bunch of configurable GPIOs which are configured as digital peripherals for different applications and control usage. Moreover, the chip also has SPI, I2C, UART serial communication interfaces, and ADC & DAC analog interfaces. Realtek, as one of the biggest suppliers of Wi-Fi solution, its Ameba-RTL8195AM offers trustworthy stability and reliability. Ameba-RTL8195AM, the first low power consuming IoT chip integrates Ethernet and NFC. It is a cheap and reliable choice for IoT developers. Caution: RTL8195AM is developer-oriented and some functions are still in testing. Please check the official website for more details. FEATURES  Support for Arduino and Micropython programing  Supports 802.11 b/g/n 1x1 Wi-Fi  Supports NFC read/write  10/100 Ethernet MII/ RMII/RGMII interface  Supports USB OTG  Supports SDIO device/SD card controller  Hardware: SSL engine  30 x GPIO(Maximum)  Supports 2 x SPI master-slave interface communication  Supports 3 x UART interface (2x HS-UART & 1x log UART)  Supports 2 x I2C master-slave interface communication  Supports 2 x I2S/PCM master-slave interface communication  Supports 4 x PWM  Supports 2 x ADC  Supports 1 x DAC  Supports ultra-low power consumption  Fast response (up to 400KHz)    SPECIFICATION  Operating Voltage: 3.0V~3.3V  Micro-Controller: 32-bit ARM Cortex M3(166MHz)  Antenna Connector: U.FL  ROM/RAM/Flash: 1MB ROM,2MB SDRAM,512KB SRAM  Wireless Network Mode: station / softAP/ SoftAP+station  Data rate: 802.11g 54Mbps (Max.), 802.11n 150Mbps (Max.)  Operating Temperature range: -20Ԩ~+85Ԩ  Dimensions: 19 x 24mm/0.75 x 0.94(inches) SHIPPING LIST Realtek Ameba-RTL8195AM WiFi & NFC Module x1                       https://www.dfrobot.com/product-1608.html 8-15-17
DFR0477 价格&库存
很抱歉,暂时无法提供与“DFR0477”相匹配的价格&库存,您可以联系我们找货
