FireBeetle ESP32 IOT Microcontroller (Supports Wi‐Fi &
Bluetooth) SKU: DFR0478
Introduction
DFRobot FireBeetle series is the low-power consumption micro-controller intentionally designed for
Internet of Things (IoT) projects. FireBeetle Board - ESP32 integrates a Dual-Core ESP-WROOM-32
module, which supports MCU and Wi-Fi &Bluetooth dual-mode communication. The electric current
is just 10μA in the deep-sleep mode. The main controller supports two power supply methods: USB
and 3.7V external lithium battery. And both USB and external DC can charge the Lipo battery
directly. FireBeetle Board-ESP32 has made a special hardware design for Arduino IDE. You
can make a download without switching booth-mode manually. It supports Arduino, IDF (linux),
micropython etc. Moreover, FireBeetle made a pin mapping for Arduino IDE. It can be configured
with Dx transport, compatible with UNO and reduce the entry barrier.
The small size and high performance makes FireBeetle become idea solution for IOT low power
consumption projects.
Please kindly note that developers are the most common users of FireBeetle Board-ESP32 and
not all of the peripherals have examples for reference, and there are still some bugs being found and
fixed. For Arduino IDE, all GPIO function, I2C/SPI communication has been working. But the other
functions are still under development. We recommend this board for experienced engineer.
Feature
Compatible with products in the DFRobot FireBeetle serials
Low-power consumption(the electricity current under ultra-low power is 10μA)
Quick Response(the top frequency is 400KHz)
Cost-effective
Small size, convenient to install
Specification
Working voltage: 3.3V
Input voltage: 3.3V~5V
Support electric current of low power consumption: 10 μA
Support maximum discharge current: 600mA
Support maximum charge current: 500mA
Support USB charging.
Processer: Tensilica LX6 dual core processer (One for high speed connection; one for independent
programing).
Frequency: 240MHz
SRAM:520KB
Flash:16Mbit
Wi-Fi standard:FCC/CE/TELEC/KCC
Wi-Fi protocol: 802.11 b/g/n/d/e/I/k/r (802.11n, high speed can reach to 150 Mbps), converge AMPDU and A-MSDU, supporting 0.4us protecting interval.
Frequency range: 2.4~2.5 GHz
Bluetooth protocol: Comply with BR/EDR/BLE standard of Bluetooth v4.2.
Bluetooth audio: the current under low power consumption of CVSD and SBC is 10μA
Working current: 80mA in average
Frequency range: 2.4~2.5GHz
Support one-key downloading.
Support micropython.
On-chip clock: 40MHz crystal and 32.768 KHz crystal.
Digital I/O: 10 (default setting of arduino)
Simulative input: 5(default setting of arduino)
SPI: 1 (default setting of arduino)
I2C: 1 (default setting of arduino)
I2S: 1 (default setting of arduino)
LED_BUILTIN:D9
Interface: FireBeetle series compatible
Working temperature: -40 ~+85
Dimension: 24 × 53(mm)/0.94 x 2.09(inches)
The dimension of mounting hole: inner diameter 3.1mm; outside diameter 6mm.
Board Overview
FireBeetle Board - ESP32 is not only compatible with ESP32 PinMap, but also make a special
compatible with Arduino IDE PinMap. Dx(x=0,1,2,3...9)
Fig1: FireBeetle Board-ESP32 PinOUT
Note: NC = Empty; VCC = VCC (5V under USB power supply, Around 3.7V under
3.7V lipo battery.power supply)
Tutorial
In this tutorial, we'll show you some basic operation with FireBeetle-ESP32 Microcontroller.
Requirements
Hardware
FireBeetle ESP32 IOT Microcontroller x 1
Micro USB Cable x1
Software
Arduino IDE (newest), Click to Download Arduino IDE from Arduino®
Download FireBeetle ESP32 Window Driver Note: Win8 + need disable the digital signature
Setup Arduino IDE Development Environment
Plug FireBeetle to your computer, install the driver manually.
Add FireBeetle Board URL to Arduino IDE
Open Arduino IDE, File->Preferences, find Additional Boards Manager URLs, copy the below
link, and paste in the blank.
https://git.oschina.net/dfrobot/FireBeetle-ESP32/raw/master/package_esp32_index.json
File->Preferences
paste url here
Click OK
Open Tools->Board->Boards Manager, waiting automatic update. You'll find FireBeetleESP32
Now, the development environment has been installed, you can use it like a normal Arduino
board.
Sample Code ‐ Blink
The default LED for FireBeetle Board-ESP32 is D9, input following code:
// the setup function runs once when you press reset or power the board
void setup() {
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(LED_BUILTIN, HIGH);
ge level)
delay(1000);
digitalWrite(LED_BUILTIN, LOW);
tage LOW
delay(1000);
// turn the LED on (HIGH is the volta
// wait for a second
// turn the LED off by making the vol
For more code and instruction, please refer to FIreBeetle User Manual
More
FireBeetle Arduino Bluetooth Examples https://github.com/Chocho2017/DFRobot_ESP32_WiFiBLE
https://www.dfrobot.com/wiki/index.php/FireBeetle_ESP32_IOT_Microcontroller_(Supports_Wi-Fi_%26_Bluetooth)_SKU:_DFR0478#More 7-7-17
很抱歉,暂时无法提供与“DFR0478”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+113.176671+14.71260
- 国内价格 香港价格
- 1+86.829311+11.28753
