DFR0482
DFR0482
    DFROBOT
    带镀层通孔 Protoboard FireBeetle 平台评估扩展板
DFR0482 数据手册
  FireBeetle Covers-Proto Board Doubler SKU:DFR0482 INTRODUCTION DFRobot FireBeetle series is the low-power consumption micro-controller intentionally designed for Internet of Things (IoT). The series micro-controllers aims at IoT node of low-power consumption, attending to build the IoT hardware platform quickly and conveniently. There are three types of FireBeetle, containing Boards (main control), Covers (expansion boards) and related Accessories. Proto Board Doubler is compatible with products of FireBeetle series. There are 14×7×2 general 2.54mm solder holes in the board of standard spacing. The two prototyping boards connect to one master board with common VCC, 3.3V and GND soldering pads. These features of Proto Board Doubler contribute to it an ideal vehicle for soldering any electronic component. Moreover, the ports compatible with other projects of FireBeetle makes it the best choice for overlay circuit prototypes. FEATURES  Compatible with products in the DFRobot FireBeetle Series, plug and play  Cost-Effective  Small size, convenient to install SHIPPING LIST  FireBeetle Covers-Proto Board Doubler x1  18 pin-2.54mm pin x4  18 pin-2.54mm long pin header x4 https://www.dfrobot.com/product-1588.html 7-7-17
DFR0482
1. 物料型号:DFR0482 - FireBeetle Covers-Proto Board Doubler。 2. 器件简介:FireBeetle系列是为物联网(IoT)设计的低功耗微控制器,旨在为IoT节点的低功耗需求提供快速方便的硬件平台。FireBeetle系列包含主控板、扩展板和相关配件。 3. 引脚分配:该板具有14×7×2,标准间距为2.54mm的通用焊盘。两个原型板通过共有的VCC、3.3V和GND焊盘连接到一个主控板上。 4. 参数特性:与FireBeetle系列产品兼容,即插即用;性价比高;体积小,便于安装。 5. 功能详解:Proto Board Doubler是理想的载体,可以焊接任何电子元件,并且与其他FireBeetle项目的端口兼容,使其成为覆盖电路原型的最佳选择。 6. 应用信息:该产品适用于IoT硬件平台的快速构建,适用于电子元件的原型制作和电路原型的叠加。 7. 封装信息:包装清单包括FireBeetle Covers-Proto Board Doubler x1、18针-2.54mm引脚x4和18针-2.54mm长引脚头x4。
DFR0482 价格&库存
很抱歉,暂时无法提供与“DFR0482”相匹配的价格&库存,您可以联系我们找货
