DFR0483
DFR0483
    DFROBOT
    Gravity 转 FireBeetle 连接性 FireBeetle 平台评估扩展板
DFR0483 数据手册
  FireBeetle Covers‐Gravity I/O Expansion Shield  SKU: DFR0483 Introduction DFRobot FireBeetle series is the low-power consumption micro-controller intentionally designed for Internet of Things (IoT). The series micro-controllers aims at IoT node of low-power consumption, attending to build the IoT hardware platform quickly and conveniently. There are three types of FireBeetle, containing Boards (main control), Covers (expansion boards) and related Accessories. FireBeetle Covers-Gravity I/O Expansion Shield is an adapter for Gravity sensors and modules. With this shield, you can achieve convenient connection between Gravity sensors and FireBeetles. Every sensor will have its independent power pins. Note: Please pay attention that the working voltage is 3.3V only. (Red pins) Features     DFRobot FireBeetle Compatible Gravity interface, plug and play, easy to use Cost-effective Small size, convenient to install Specification            Input voltage:3.7V~5.5V (VCC) Output voltage:3.3V Supports low-power consumption Mode: POWER_EN = LOW Support maximum discharge current: 600mA(Output voltage: LDO-3.3V ) Interface: Gravity standard interface. Digital I/O Pins: 10 Analog Input Pins: 5 Supports I2C x1 Supports UART x1 Supports SPI x1 Dimension: 29.00×58.00mm Board Overview FireBeetle Covers-Gravity I/O Expansion Shield  1 Label Description POWER_EN Low-power Consumption Enable Pin (Default: HIGH), POWER_EN = LOW, 3V3 Pins (Red) = 0V; POWER_EN = HIGH, 3V3 Pins (Red) = 3.3V; 2 SS SPI SS (CS) Pin: D2, D3, D4, D5 Dimension https://www.dfrobot.com/wiki/index.php/FireBeetle_Covers-Gravity_I/O_Expansion_Shield_SKU:_DFR0483 7-7-17
DFR0483 价格&库存
很抱歉,暂时无法提供与“DFR0483”相匹配的价格&库存,您可以联系我们找货
DFR0483
    • 1+60.846971+7.87218
    DFR0483
      • 1+13.194951+1.70712
      库存:47
      DFR0483
      • 5+13.425095+1.73690
      库存:47
