DFR0498
DFR0498
    DFROBOT
    FIREBEETLE COVERS-CAMERA&AUD
DFR0498 数据手册
FireBeetle Covers-Camera&Audio Media Board SKU:DFR0498 Introduction DFRobot FireBeetle series are low power consumption development modules designed for Internet of Things (IoT). The FireBeetle Covers-Camera & Audio Media Board is a multimedia device for IoT that provides interfaces to connect NAU8822 CODEC IIS, OV7725 camera, SD card (SDIO), earphone and microphone. Moreover, it equips with a mini MIC input interface. The NAU8822 CODEC IIS can drive both 12@8Ω BTL loudspeaker and 40mW@16Ω earphone. The direct connection is supported. Meanwhile, NAU8822 supports DAC sound signal acquisition and programmable microphone amplifier. The recording is available when input voices with onboard MIC interface or microphone then save it to SD card. What's more, the function to take photos is available when connected to an OV7725 CAMERA. With any FireBeetle main boards (e.g. ESP32 main board), the FireBeetle Covers-Camera & Audio Media Board could be a MP3, a recorder, a camera. Once connected to the Internet, it could be an Internet radio, a cloud image recognition. NOTE • • • This media board only supports FireBeetle ESP32 main board at present, for other main boards do not equipped with IIS interface. The flat ribbon cable of camera is relatively easy-to-break, please be careful and light in connection. The camera shot must be opposite to the SD card slot. Do not support video shooting and transmission. Specification • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Operating Voltage: 3.7V~5.5V (VCC) Output Voltage: 3.3V User-defined Button: tested by IO16(DI) RESET x1 SD Card: Bus Interface: SDIO Protocol Default Transmission Rate: 10MHz Max. Transmission Rate: 20MHz Camera OV7725: (data as below is just for reference; some functions could not be realized by ESP32 now). Photosensitive/Light-sensitive Array: 640*480 Optical Size: 1/6" Angle of View: 25° SCCB Standard Interface Output Pixel Format: Raw RGB,RGB(RGB4:2:2 ,RGB565/555/444),YCbCr (4:2:2) Image Size: VGA,QVGA and CIF to 40x30 VarioPixel Subsampling Auto Image Control: auto exposure control (AEC), auto gain control (AGC), auto white balance (AWB), auto band filter and auto black level (ABL) calibration. Image Quality Control: saturation, tone, gamma, clarity and anti-interference ISP: noise reduction and defect calibration Lens Shading Correction Auto Saturation Adjustment Frame Synchronization Fixed-focus NAU8822: DAC:94dB SNR , -84db THD ADC:90dB SNR , -80dB THD Integrated BTL loudspeaker drive: 1W @ 8Ω Integrated earphone drive: 40mW @ 16Ω Integrated programmable microphone amplifier Typical Sampling Rate: 8KHz, 48KHz, 96KHz, 192KHz Standard Video Interface: PCM and I2S MIC: Type: Electret Capacitor Output: analog Direction: omnidirectional • • • Frequency Range: 100Hz~15KHz Sensitivity: -43dB ±5dB @ 94dB SPL Signal-to-noise Ratio: 58Db Function Diagram FireBeetle Covers-Camera&Audio Media Board Board Overview DFR0498 PinOut ESP32 SD Card IO0 NAU8822 Camera DACIN RST BLCK D3 LRCK D2 IO1 IO2 DATA0 IO3 IO4 DATA1 IO5 IO6 IO7 IO8 IO9 IO10 IO11 IO12 DATA2 IO13 DATA3 IO14 CLK IO15 CMD IO16 IO17 IO18 D4 IO19 D5 IO21 XCLK IO22 MCLK PCLK IO23 HREF IO25 VSYNC IO26 SDIO SDA IO27 SCLK SCL IO34 D8 IO35 D9 IO36 D6 IO39 ADCOUT D7 Tutorial Requirements • • • • • • • Hardware ESP32 x1 FireBeetle Covers-Camera&Audio Media Board x1 OV7725 Camera x1 Micro SD Card (FAT32 File System) x1 Software Arduino IDE (Version requirements: V1.8+), click to Download Arduino IDE from Arduino® Play Download programs as below to ESP32 main control board and plug a SD Card with test1.wav and test2.wav Sample Code (Music Play) Please download and install FireBeetle Covers-Camera&Audio Media Board library files. How to install Libraries in Arduino IDE /*! * @file DFRobot_IIS.h * @brief DFRobot's IIS Player Module * @n IIS Module for how to begin to play a WAV file,how to excute orders pau se,continue,stop and play the next * Insert sd card with test1.wav and test2.wav. * Call the function by pressing user key to control music player * The Module would operate as follows when pressed: play test1.wav>>pause >>continue>>mute>>Volume:50>>stop>>play test2.wav */ #include #include "DFRobot_IIS.h" DFRobot_IIS iis; const int buttonPin = 16; int i=0; void setup() { Serial.begin(115200); iis.SDCardInit(); // Init SD card iis.init(AUDIO); // Init Audio mode iis.setHeadphonesVolume(50); rom 0 to 99 // Set Headphones Volume f iis.setSpeakersVolume(50); rom 0 to 99 // Set Speakers iis.initPlayer(); Volume f // Init Music player Serial.println("Init player"); iis.playMusic("/test1.WAV"); // Choose music file Serial.println("Ready to play"); delay(500); } void loop(){ static unsigned long timepoint = millis(); static byte count = 0; if(millis()-timepoint > 200){ if((!digitalRead(buttonPin))&&(i==0||i==2)){ timepoint = millis(); iis.playerControl(PLAY); ng Music Serial.println("play"); // Start or continue playi i++; }else if((!digitalRead(buttonPin))&&i==1){ timepoint = millis(); iis.playerControl(PAUSE); // Pause playing Serial.println("pause"); i++; }else if((!digitalRead(buttonPin))&&i==3){ timepoint = millis(); iis.muteSpeakers(); // Mute mode iis.muteHeadphones(); Serial.println("mute mode"); i++; }else if((!digitalRead(buttonPin))&&i==4){ timepoint = millis(); iis.setHeadphonesVolume(50); iis.setSpeakersVolume(50); Serial.println("Volume=50"); i++; }else if((!digitalRead(buttonPin))&&i==5){ timepoint = millis(); iis.playerControl(STOP); // Stop playing Serial.println("Stop"); i++; }else if((!digitalRead(buttonPin))&&i==6){ timepoint = millis(); iis.playMusic("/test2.WAV"); // Change music file iis.playerControl(PLAY); // Play test2.wav i=1; } delay(100); } } • Program Function: The Module would operate as follows when pressed: play test1.wav>>pause>>continue>>mute>>Volume:50>>stop>>play test2.wav • Functions: • SDCardInit(): • Initialize SD card in the beginning. • init(AUDIO): • Enter AUDIO mode, state its mode (AUDIO / CAMERA) in use when the SD card is initialized. • setHeadphonesVolume(50),setSpeakersVolume(0): • Set earphone volume and loudspeaker volume separately. They can be used at the same time and the volume range is 0~99. It should be set before the player initialization and can be used to change volumes in the play. • muteSpeakers(),muteHeadphones(): • Mute: enable loudspeaker and earphone to Mute, available in the play. • initPlayer(): • Initialize the player: to prepare for calling the player function in AUDIO • playMusic("/test1.WAV"): • Select a music file (test1.wav at here) that stored in the SD card and call to play. • playerControl(PLAY),playerControl(PAUSE),playerControl(STOP): • Player control: to play, pause and stop the music play in order. Record Once the board connected to microphone by MIC, the other onboard microphone is disabled. Download programs as below to ESP32 main control board and plug a SD Card. /*! * @file DFRobot_IIS.h * @brief DFRobot's IIS Record Module * @n IIS Module for Record sound and Save WAV file in SD card * Insert sd card * Call the function by pressing user key to control recorder * This Module will record sound and save it as record.wav then play recor d.wav */ #include #include DFRobot_IIS iis; const int buttonPin = 16; enum Status{ ePrepare, eRecording, eStop }eState=ePrepare; void setup(){ Serial.begin(115200); iis.SDCardInit(); // SD card init iis.init(AUDIO); // Init Audio mode iis.initRecorder(); // Init recorder iis.initPlayer(); // Init musice player iis.record("/record.WAV"); recording // Enter file name to save Serial.println("Ready to record"); } void loop(){ static unsigned long timepoint = millis(); static byte count = 0; if(millis()-timepoint > 200){ if((!digitalRead(buttonPin))&&eState==ePrepare){ timepoint = millis(); iis.recorderControl(BEGIN); Serial.println("Recording"); // Begin recording eState=eRecording; }else if((!digitalRead(buttonPin))&&eState==eRecording){ timepoint = millis(); iis.recorderControl(STOP); // Stop recording Serial.println("Stop and save data"); eState=eStop; }else if((!digitalRead(buttonPin))&&eState==eStop){ timepoint = millis(); iis.playMusic("/record.WAV"); // Play your record iis.setSpeakersVolume(50); iis.setHeadphonesVolume(50); iis.playerControl(PLAY); eState=ePrepare; } delay(100); } } Program Function: Pressing to record when downloaded, repressing the button to stop and save the file: record.wav to SD card and press to play it. • Functions: • SDCardInit(): • Initialize SD card in the beginning. • init(AUDIO): • Enter AUDIO mode, state its mode (AUDIO / CAMERA) in use when the SD card is initialized. • initRecorder(): • Initialize the recorder: to prepare for calling the record function in AUDIO. • record("/record.WAV"): • Name the record file that will be saved to the SD card, call and play. • recorderControl(BEGIN),recorderControl(STOP): • Recorder control: to play, pause, stop and save in order. Take Photos • • • Due to the limitation of ESP32 processing performance, it only supports 320x240 QVGA resolution for now. And the network transmission picture only supports GRAYSCALE photo, the next version will supports colorful image. Fixed focus, no need to adjust. Download programs as below to ESP32 main control board and plug a SD Card /*! * @file DFRobot_IIS.h * @brief DFRobot's IIS Camera Module * @n IIS Module for take photo and save BMP file in SD card * Insert sd card * Call the function by pressing user key to take photo * This Module will take photo and save as photo1.bmp,photo2.bmp by pressi ng user key */ #include #include "DFRobot_IIS.h" DFRobot_IIS iis; const int buttonPin = 16; int i=0; const char* SSID ="yourSSID"; const char* PASSWORD="SSID password"; void setup(){ Serial.begin(115200); pinMode(buttonPin, INPUT); iis.SDCardInit(); //SD card init iis.init(CAMERA); //Init Camera mode iis.connectNet(SSID,PASSWORD); //Connect wifi iis.setFramesize(QVGA); 0x240 //Set photo size QVGA:32 iis.setPixformat(GRAYSCALE); //Set pixelformat GRAYSC iis.sendPhoto(); //Send photo to net ALE delay(100); Serial.println("Ready to take photo"); } void loop(){ static unsigned long timepoint = millis(); static byte count = 0; if(millis()-timepoint > 20){ timepoint = millis(); if(!digitalRead(buttonPin)&& i == 0){ Serial.println("take photo1"); iis.snapshot("/photo1.bmp"); as photo1.bmp in SD card //Take photo and save it Serial.println("done"); i=1; } if(!digitalRead(buttonPin)&& i == 1){ Serial.println("take photo2"); iis.snapshot("/photo2.bmp"); as photo1.bmp in SD card //Take photo and save it Serial.println("done"); i=0; } } } • • Program Function: Press the button to take a photo, saving as photo1.bmp. Press the button again to take another photo, saving as photo2.bmp. Please pay attention that you can keep pressing button to take photo, but it will cover photo1 and photo2 in turn. Functions: • SDCardInit(): • Initialize SD card in the beginning. • init(CAMERA): • Enter CAMERA mode, state its mode (AUDIO / CAMERA) in use when the SD card is initialized. • connectNet(SSID,PASSWORD): • Connect to Wi-Fi, SSID and PASSWORD are the name and the password of Wi-Fi been used. • setFramesize(QVGA): • Set image frame size and it need to be called in CAMERA mode, supporting QQVGA (160x120) QQVGA2 (128x160) QICF (176x144) HQVGA (240x160) QVGA (320x240). • iis.setPixformat(GRAYSCALE): • Set pixel format and it need to be called in CAMERA mode, supporting RGB555 (colorful), GRAYSCALE. • sendPhoto(): • Connect to Wi-Fi and transmit CAMERA data to the Internet, the CAMERA shooting (GRAYSCALE) can be checked by referring the tutorial and image as below. • snapshot("/photo1.bmp"): • Function to take a photo: Name the image file (photo1.bmp in SD card at here) to be saved, call the function to take a photo and save. Tutorial to get a photo: Click to download the software tool in need. Open the software tool. • • • • Run the program and open the serial port to check IP address. • Input IP address. (PC and ESP32 main board should be in a same network segment), click start to take a photo in a real time. SD Card Read & Write • • ESP32 SDMMC library of official Arduino can be directly used in SD card socket of FireBeetle Covers-Camera&Audio Media Board. Plug SD card and download the below program to ESP32 mainboard. #include "FS.h" #include "SD_MMC.h" /*Print file list*/ void listDir(fs::FS &fs, const char * dirname, uint8_t levels){ Serial.printf("Listing directory: %s\n", dirname); File root = fs.open(dirname); if(!root){ Serial.println("Failed to open directory"); return; } if(!root.isDirectory()){ Serial.println("Not a directory"); return; } File file = root.openNextFile(); while(file){ if(file.isDirectory()){ Serial.print(" DIR : "); Serial.println(file.name()); if(levels){ listDir(fs, file.name(), levels -1); } } else { Serial.print(" FILE: "); Serial.print(file.name()); Serial.print(" SIZE: "); Serial.println(file.size()); } file = root.openNextFile(); } } /*Create content*/ void createDir(fs::FS &fs, const char * path){ Serial.printf("Creating Dir: %s\n", path); if(fs.mkdir(path)){ Serial.println("Dir created"); } else { Serial.println("mkdir failed"); } } /*Delete content*/ void removeDir(fs::FS &fs, const char * path){ Serial.printf("Removing Dir: %s\n", path); if(fs.rmdir(path)){ Serial.println("Dir removed"); } else { Serial.println("rmdir failed"); } } /*Read file*/ void readFile(fs::FS &fs, const char * path){ Serial.printf("Reading file: %s\n", path); File file = fs.open(path); if(!file){ Serial.println("Failed to open file for reading"); return; } Serial.print("Read from file: "); while(file.available()){ Serial.write(file.read()); } } /*Write file*/ void writeFile(fs::FS &fs, const char * path, const char * message){ Serial.printf("Writing file: %s\n", path); File file = fs.open(path, FILE_WRITE); if(!file){ Serial.println("Failed to open file for writing"); return; } if(file.print(message)){ Serial.println("File written"); } else { Serial.println("Write failed"); } } /*Append Writefile*/ void appendFile(fs::FS &fs, const char * path, const char * message){ Serial.printf("Appending to file: %s\n", path); File file = fs.open(path, FILE_APPEND); if(!file){ Serial.println("Failed to open file for appending"); return; } if(file.print(message)){ Serial.println("Message appended"); } else { Serial.println("Append failed"); } } /*Rename file*/ void renameFile(fs::FS &fs, const char * path1, const char * path2){ Serial.printf("Renaming file %s to %s\n", path1, path2); if (fs.rename(path1, path2)) { Serial.println("File renamed"); } else { Serial.println("Rename failed"); } } /*Delete file*/ void deleteFile(fs::FS &fs, const char * path){ Serial.printf("Deleting file: %s\n", path); if(fs.remove(path)){ Serial.println("File deleted"); } else { Serial.println("Delete failed"); } } /*Test Read&White speed*/ void testFileIO(fs::FS &fs, const char * path){ File file = fs.open(path); static uint8_t buf[512]; size_t len = 0; uint32_t start = millis(); uint32_t end = start; if(file){ len = file.size(); size_t flen = len; start = millis(); while(len){ size_t toRead = len; if(toRead > 512){ toRead = 512; } file.read(buf, toRead); len -= toRead; } end = millis() - start; Serial.printf("%u bytes read for %u ms\n", flen, end); file.close(); } else { Serial.println("Failed to open file for reading"); } file = fs.open(path, FILE_WRITE); if(!file){ Serial.println("Failed to open file for writing"); return; } size_t i; start = millis(); for(i=0; i
DFR0498 价格&库存
很抱歉,暂时无法提供与“DFR0498”相匹配的价格&库存,您可以联系我们找货
DFR0498
  • 1+231.271911+29.94500
  • 3+204.130193+26.43070
库存:2
DFR0498
  • 1+189.472341+24.53281
