DFR0505
DFR0505
    DFROBOT
    SIM7000C GSM/GPRS RF Arduino 平台评估扩展板
DFR0505 数据手册
SIM7000C Arduino NB-IoT/LTE/GPRS Expansion Shield SKU: DFR0505 NB-IoT(Narrow Band-Internet of Things) technology is a new IoT technical branch and supports cellular data network connection of low power consumption device in WAN (Wide Area Network), which also called as LPWAN. NB-IoT operates in authorized frequency spectrum. It can be directly deployed to GSM, UMTS, LTE without any interference of current networks, while the bandwidth consumption is just about 180KHz. This SIM7000C Arduino NB-IoT/LTE/GPRS expansion shield is a wireless communication module produced by DFRobot and the design is based on SIMCom SIM7000C chip. This wireless communication module is designed for Arduino controllers, supporting multi-frequency LTE-FDD communication, dual-frequency GPRS/EDGE communication, NB-IoT communication. No matter prototype developments or small-batch productions, SIM7000C Arduino NB-IoT/LTE/GPRS expansion shield is the best solution to applications of low power consumption, low latency and meddle-throughput. Besides onboard GNSS (Global Navigation Satellite System), SIM7000C supports American GPS, Russian GLONASS, European Galileo, Japanese QZSS and Chinese BeiDou Navigation Satellite System. It can be widely applied to IoT applications such as long distance control, moving tracking, long distance data uploading and shared bikes. The SIM7000C Arduino NB-IoT/LTE/GPRS expansion shield supports both SIM card and NB-IoT card synchronously. You can plug in a common SIM card to achieve traditional GSM applications, such as make a phone call and send message. You can also plug in a NB-IoT card to realize NB-IoT data transmission. Besides, this expansion shield provides a BME280 environmental sensor. So it could be a prototype to develop NB-IoT projects, monitoring temperature, humidity and pressure. Specification • • • • • • • • • • • • • • • • • • • • Input Voltage: 7~12VDC (VIN range: 6~20V) Communication Module: SIM7000C Single-Band TDD-LTE B39 Quad-Band FDD-LTE B1/B3/B5/B8 GPRS/EDGE 900/1800 MHz Output power GSM900: 2W DCS1800: 1W Control Via AT Commands Operation temperature: -40℃ to +85℃ GNSS (GPS, GLONASS, BeiDou, Compass, Galileo, QZSS) Firmware update via USB 2.0 Support SIM card and NB-IoT card (NOTE: Please ensure the SIM frequency range been used is included in the frequency range it supported). BME280 Environmental Sensor Temperature Measuring Range: -40℃~+85℃, resolution of 0.1℃, deviation of ±0.5℃ Humidity Measuring Range: 0~100%RH, resolution of 0.1%RH, deviation of ±2%RH Pressure Measuring Range: 300~1100hPa Humidity Sampling Time: 1s Operating Temperature:-30℃~+85℃ Dimension: 2.1 x 2.7inch /53.4 x 68.6mm Board Overview NOTE: 1. Software/Hardware Serial Port Switch: Arduino UNO/Mega controllers connect USB with the hardware interface D0,D1 in default. So serial port conflicts are common when serial ports are used by the expansion shields. Considering these conflicts, SIM7000C Arduino NB-IoT/LTE/GPRS expansion shield equipped with a software serial port to communicate with Arduino. Learn more about Arduino SoftwareSerial Library. 2. Boot button connected to D12 in default to control program conveniently. You can pull up D12 for 2s to ON/OFF. SIM7000C ON will initialize to get ready to work in about 2s. Tutorial(Based on SIM7000 Library) Requirements • • • • • Hardware DFR0216 DFRduino UNO R3 - Arduino Compatible x1 DFR0505 SIM7000C Arduino NB-IoT/LTE/GPRS Expansion Shield x1 USB Wire x1 7V~12V DC Power Supply x1 • • • Software Arduino IDE, Click to Download Arduino IDE from Arduino® Please click to download NB-IoT SIM7000 Shield Library. How to install Libraries in Arduino IDE. Connection Diagram Plug the SIM7000C Arduino NB-IoT/LTE/GPRS Expansion Shield to DFRduino UNO R3 directly. SIM7000C Arduino NB-IoT/LTE/GPRS Expansion Shield Connection Diagram Sample Code • • Since Arduino UNO only has one hardware port, which will make a conflict with the other Serial device, DFRobot_SIM7000 Library will use SoftwareSerial as communication port. Please turn the switch to the terminal "Tx>D8; Rx > D7". The program uses SIM7000 to achieve HTTP message interaction. #include #include #define PIN_TX 7 #define PIN_RX 8 SoftwareSerial mySerial(PIN_RX,PIN_TX); DFRobot_SIM7000 sim7000; static char buff[350]; void setup(){ int signalStrength,dataNum; Serial.begin(115200); sim7000.begin(mySerial); sim7000.turnOFF(); delay(5000); Serial.println("Turn ON SIM7000......"); if(sim7000.turnON()){ //Turn ON SIM7000 Serial.println("Turn ON !"); } Serial.println("Set baud rate......"); if(sim7000.setBaudRate(19200)){ //Set baud rate from 115200 to 19200 Serial.println("Set baud rate:19200"); }else{ Serial.println("Faile to set baud rate"); while(1); } Serial.println("Check SIM card......"); if(sim7000.checkSIMStatus()){ //Check SIM card Serial.println("SIM card READY"); }else{ Serial.println("SIM card ERROR"); while(1); } delay(500); Serial.println("Set net mod......"); if(sim7000.setNet(NB)){ //Set net mod NB-IOT Serial.println("Set NB-IOT mode"); }else{ Serial.println("Fail to set mode"); } Serial.println("Get signal quality......"); delay(500); signalStrength=sim7000.checkSignalQuality(); //Check signal quality from (0-30) Serial.print("signalStrength ="); Serial.println(signalStrength); delay(500); Serial.println("Attaching service......"); if(sim7000.attacthService()){ //Open the connection Serial.println("Attach service"); }else{ Serial.println("Fail to Attach service"); while(1); } delay(200); Serial.println("Connecting......"); if(sim7000.connect(TCP,"www.taobao.com",80)){ //Start Up TCP or UDP Connection Serial.println("Connect OK"); }else{ Serial.println("Fail to connect"); while(1); } sim7000.send("HEAD/HTTP/1.1\r\nHost:www.taobao.com\r\nConnection:keepalive\r\n\r\n"); //Send Data Through TCP or UDP Connection dataNum=sim7000.recv(buff,350,0); //Receive data Serial.print("dataNum="); Serial.println(dataNum); Serial.println(buff); delay(500); if(sim7000.close()){ //End the connection Serial.println("Close connection"); }else{ Serial.println("Fail to close connection"); } delay(2000); sim7000.turnOFF(); //Turn OFF SIM7000 } void loop() { delay(1000); } • • Function: Set software serial port. SIM7000 uses the software serial port to control TX to D8, RX to D7. • begin(Stream &s_) • Turn ON SIM7000 in a software way then Net indicator will blink. SIM7000C will initialize for about 2s. The function back to true when initialized successfully. • • • turnON(); Turn OFF SIM7000 in a software way then Net indicator will go out. turnOFF(); • Set baud rate of software serial port, SIM7000 serial port recognize 115200 baud rate in default. So we need to reset the baud rate to 19200 and below to avoid garbled. The function back to true when initialized successfully (other qualified baud rates are 9600, 4800, 2400, 1200). • setBaudRate(int rate); • Initialize AT commands and the function back to true when initialized successfully. • checkSIMStatus(); • Set network mode and the function back to true when initialized successfully. Qualified modes: GPRS/GPRS-NB/NB-IOT • setNet(Net net); • Check signal strengths, the return value is the signal strength. Return=99 means no signal can be detected. • checkSignalQuality(); • Start a connection service and the function back to true when connected successfully. • attacthService(); • Connect to network: select a connection protocol (TCP/UDP), domain name, port ID. The function back to true when initialized successfully. • connect(Protocol ptl,const char *host, int port); • Data transmission: send data to the server when connected. Data size can be specified or inputted directly. • send(const char *str); • send(void* buf,size_t len); • Receive data: receive and save data from the server. The maximum data to receive and waiting time can be set. The result is the character value been received. • recv(char* buf,int maxlen,int timeout); • Disconnect and the function back to true. • close(); • Project Display: NBIOT-Project Display Tutorial(Based on AT Commands) Requirements Same as SIM7000 library, please refers to the tutorial mentioned before. Connection Diagram Same as SIM7000 library, please refers to the tutorial mentioned before. Sample Code • • • SIM7000 NB-IoT Shield can be controled by AT command through serial port and it recognizes 115200 baud rate in default. So we need to reset the baud rate to 19200 and below to avoid garbled. (The software serial port has an unreliable baudrate higher than 38400bps.) AT command must end with a CR&LF, shown as below: AT command list: /* * File : DFRobot_SIM7000_ATtest.ino * Power : SIM7000 needs 7-12V DC power supply * Brief : This example use the serial port to send AT command to control the SIM7000 * With initialization completed, we can enter AT command to SIM7000 dire ctly * Note : If you use Mega please connect PIN8 PIN10 and set PIN_RX = 10 * The AT command must end with CR&LF */ #include #define PIN_TX 7 #define PIN_RX 8 SoftwareSerial mySerial(PIN_RX,PIN_TX); DFRobot_SIM7000 sim7000; void setup() { Serial.begin(115200); sim7000.begin(mySerial); sim7000.turnOFF(); delay(5000); Serial.println("Turn ON SIM7000......"); if(sim7000.turnON()){ Serial.println("Turn ON !"); } //Turn ON SIM7000 Serial.println("Set baud rate......"); if(sim7000.setBaudRate(19200)){ 115200 to 19200 //Set baud rate from Serial.println("Set baud rate:19200"); }else{ Serial.println("Faile to set baud rate"); while(1); } mySerial.begin(19200); Serial.println("For example, if you type AT\\r\\n, OK\\r\\n will be re sponsed!"); Serial.println("Enter your AT command :"); } void loop() { mySerial.listen(); while(mySerial.available()){ Serial.write(mySerial.read()); } mySerial.flush(); while(Serial.available()){ mySerial.write(Serial.read()); } delay(20); } Input AT command to Uno serial port when the program runs and you can directly control SIM7000 with AT command. Click to download AT command sheet. Common AT command Introduction: Common AT command Introduction command Introduction Preferred network mode selection AT+CNMP=? Parameters 2 Automatic 13 GSM only 38 LTE only 51 GSM and LTE only AT+CNMP=2 indicates automatic network-searching mode. AT+CNMP=13 indicates only use GSM. AT+CNMP=38 indicates use compound “CATM1+NBIoT”. AT+CNMP=51 indicates use compound “GSM+CAT-M1+NBIoT”. Preferred LTE network mode selection AT+CMNB=? Parameters 1 CAT-M 2 NB-Iot 3 CAT-M and NB-IoT AT+CMNB=1 means set to CAT-M1 mode AT+CMNB=2 means set to NBIoT mode AT+CMNB=3 means set to compound CAT-M1 + NBIoT mode Signal quality report AT+CSQ Parameters 0 -115 dBm or less 1 -111 dBm 2...30 -110... -54 dBm 31 -52 dBm or greater 99 not known or not detectable (in percent): 0...7 As RXQUAL values in the table in GSM 05.08 [20] subclause 7.2.4 99 Not known or not detectable Attach or detach from GPRS service AT+CGATT? Parameters Indicates the state of GPRS attachment 0 Detached 1 Attached Other values are reserved and will result in an ERROR response to the Write Command. AT+CSTT Start task and set APN, user name, password AT+CIFSR Get local IP address Start up TCP or UDP connection AT+CIPSTART="ptl","host","port" AT+CIPSEND="len" : connection domain name to input concrete domain name or IP address. Remote server port Send data Len: data length , input date to be sent after return”>”. AT+CIPCLOSE Close TCP or UDP Connection AT+CIPSHUT Deactivate GPRS PDP Context • Project Display: NBIOT-Project Display Tutorial(Get Position) Requirements Same as SIM7000 library, please refers to the tutorial mentioned before. Connection Diagram Connect to an active antenna and use it outdoors. Sample Code #include #include DFRobot_SIM7000 sim7000; SoftwareSerial erial mySerial(8,7); //Set s void setup(){ int signalStrength,dataNum; Serial.begin(115200); sim7000.begin(mySerial); sim7000.turnOFF(); delay(5000); if(sim7000.turnON()){ ON SIM7000 //Turn Serial.println("Turn NO SIM7000"); } if(sim7000.setBaudRate(19200)){ aud rate from 115200 to 19200 //Set b Serial.println("Set baud rate:19200"); }else{ Serial.println("faile to set baud rate"); } while(1){ if(sim7000.init()){ SIM7000 Serial.println("AT command READY"); break; }else{ Serial.println("AT command ERROR"); delay(500); } } while(1){ if(sim7000.initPos()){ Serial.println("Positioning function initialized"); break; }else{ Serial.println("Fail to init positioning function"); delay(500); } } //Init } void loop(){ Serial.println("Enter anything to get positioning "); char loge[10]; readSerial(loge); Serial.println("Getting position......"); if(sim7000.getPosition()){ he current position //Get t Serial.print("Longtude :"); Serial.println(sim7000.getLongitude()); //Get l ongitude Serial.print("Latitude :"); Serial.println(sim7000.getLatitude()); atitude }else{ Serial.println("Wrong data try again"); } } int readSerial(char result[]){ int i = 0; while(1){ while(Serial.available() > 0){ char inChar = Serial.read(); if(inChar == '\n'){ result[i] = '\0'; Serial.flush(); return 0; } if(inChar != '\r'){ result[i] = inChar; i++; } } } //Get l } • • • Function: Initialize the position function. The function back to true when initialized successfully. initPos(); • Get current position and the function back to true when initialized successfully. • getPosition(); • Get current longitude: the east one is a positive number and a west longitude is a negative number (-180,180). • • • getLongitude(); Get current latitude: the east one is a positive number and a west longitude is a negative number (-90, 90). getlatitude(); BME280 Environmental Data Monitoring SIM7000C equipped with a BME280 environmental sensor, which recognize IIC connection in default. Please click to download the Arduino library file first before using. Sample Code /*! * @file basicTestI2C.ino * @brief DFRobot's Temperature、Pressure、Humidity and Approx altitude * @n [Get the module here] * @n This example read the Temperature、Pressure、Humidity and Altitude fr om BME280, and then print them * @n [Connection and Diagram] * * @copyright [DFRobot](http://www.dfrobot.com), 2016 * @copyright GNU Lesser General Public License * * @author [yangyang] * @version * @date V1.0 2017-7-5 */ #include #define SEA_LEVEL_PRESSURE 1013.25f #define BME_CS 10 DFRobot_BME280 bme; //I2C float temp, pa, hum, alt; void setup() { Serial.begin(115200); // I2c default address is 0x76, if the need to change please modify bm e.begin(Addr) if (!bme.begin()) { Serial.println("No sensor device found, check line or address!"); while (1); } Serial.println("-- BME280 DEMO --"); } void loop() { temp = bme.temperatureValue(); pa = bme.pressureValue(); hum = bme.humidityValue(); alt = bme.altitudeValue(SEA_LEVEL_PRESSURE); Serial.print("Temp:"); Serial.print(temp); Serial.println(" C"); Serial.print("Pa:"); Serial.print(pa); Serial.println(" Pa"); Serial.print("Hum:"); Serial.print(hum); Serial.println(" %"); Serial.print("Alt:"); Serial.print(alt); Serial.println(" m"); Serial.println("------END------"); delay(1000); } NOTE: DFRobot_BME280 bme // IIC sentence mentioned in the sample code is to initialize IIC drive. SIM7000C Arduino NB-IoT/LTE/GPRS Expansion Shield IIC Adjustment Compatibility Test MCU Arduino Uno Pass Failed Not Tested Remark √ Arduino Leonardo √ Arduino Mega1280 √ Connect D8 to D10 Arduino Mega2560 √ Connect D8 to D10 For any questions, advice or cool ideas to share, please visit the DFRobot Forum. More Documents • • • • • Circuit Diagram and Dimension SIM7000 Hardware Design Manual SIM7000 AT Command Manual V1.01 SIM7000 Specification BME280 Datasheet https://www.dfrobot.com/wiki/index.php/SIM7000C_Arduino_NB-IoT/LTE/GPRS_Expansion_Shield_SKU:_DFR0505 4-3-18
DFR0505 价格&库存
很抱歉,暂时无法提供与“DFR0505”相匹配的价格&库存,您可以联系我们找货
