DFR0506
DFR0506
    DFROBOT
    电容性 智能,智慧,发光二极管,图形 红色,绿色,蓝色(RGB) HDMI 7"(177.80mm) 1024 x 600
DFR0506 数据手册
7'' HDMI Display with Capacitive Touchscreen(Compatible with Raspberry Pi) SKU:DFR0506 Introduction This is a 7" HDMI display with capacitive touchscreen. It comes with a 7" LCD screen with capacitive touch panel overlay on it. The touch panel supports up to 5 touch points. And it adopts DFRobot USB free-driver technology, no special requirement of drivers. You can use it as easy as keyboard or mouse. It can be directly plugged to PC for touching control. In combination with HDMI HD screen, it can turn a large PC to a tablet immediately. The screen supports Windows, Linux and MAC OS. It can be used on Lattepanda, Raspberry Pi and other HDMI device. We also make some special hole to make it compatible with Arduino screw hole. You can mount them on the back of the display directly. There is no need for external power supply for the screen, it can be powered by USB port and HDMI port. The display also supports back light adjustment. It is very convenient to adjust backlight by potentiometer on the back of the display. Note: Please guarantee the external power supply current is above 1.5A@5V when it is driven by raspberry Pi. The lower current will reduce the touching sensitivity. Features • Capacitive Touchscreen, Support 5 Touch Points • HDMI Interface • USB Power Supply, Driver-free Installation Specification • Operating Voltage: 5V • Operating Current: 160mA (with HDMI connection) • Maximum Operating current: 1200mA • Refresh Frequency: 43Hz (not recommended 60Hz, it will not be full screen) • Screen Resolution: 1024x600 • Viewing Angle: 60°/70°/70°/70° • Number of Touch Points: 5 • RGB888-16 Mega True Color • Video Interface: HDMI • Touch Interface: Micro-USB • Outline Dimensions: 165mm x 100mm/6.50" x 3.94" • Mounting Hole Size: M2.5 • Outside Mounting Size: 155mm x 90mm/6.10" x 3.54" • Inside Mounting Size: 58mm x 49mm/2.83" x 1.93" • Weight: to be continued... Screen Overview • Standard HDMI • Standard Micro USB Tutorial Touchscreen with Raspberry Pi You need to reset resolution to avoid touch differentiation caused by resolution difference between Raspberry Pi and the Touchscreen. • Enter /boot/config.txt, modify or add the project as below: #### remove black borders disable_overscan=1 #### set specific CVT mode hdmi_cvt 1024 600 60 6 0 0 0 #### set CVT as default hdmi_group=2 hdmi_mode=87 NOTE: Windows and MAC operating system can capture resolution automatically, so you don't need to modify any parameter. Firmware Update Dfu-util (Device Firmware Upgrade Utilities) is a free, open-source, cross-platform firmware update program, it is easy to update firmware for devices with microcontrollers without platform limitations. More information: http://dfu-util.sourceforge.net In Windows 1. Download the USB installation tool zadig.exe Address: http://zadig.akeo.ie/downloads/zadig_2.2.exe 2. Enter dfu mode Short-circuit the boot's two pins, and then connect it to the computer via USB 3. Install winUSB Click Options, check All Devices(1) Select "STM32 DFU" in the drop-down box (2) Select "WinUSB" (3) Click Install Driver(4) If there is a dialog box, click Continue to install. When installing winUSB with zadig fails, the following interface will appear. (Win10 does not have the same situation.) Win 7 (32-bit/64-bit) Download msvcr100d.dll, place it in the C:\Windows\System32 directory, and then re-install the driver. There will be no mistakes. Win 8 32-bit Download msvcr100d.dll, place it in the C:\Windows\System32 directory, and then re-install the driver. 64-bit Download msvcr100d.dll, place it in the same directory as zadig.exe. (There will be a new error in the C:\Windows\System32 directory) • 4. Download the dfu-util tool 32-bit Click to download 64-bit Click to download • 5. Extract the file to your computer, such as "Desktop > dfu-util-0.9-win64", and use it without installation • 6. Firmware update, Click to download, unzip and copy the xxxx.dfu, erase.bin, and upload.py from the windows directory to the "desktop > dfu-util-0.9-win64". • 7. Run upload.py (Windows need to install python firstly. Click to download. • 8. The following interface appears, indicating that the program is being burned. • 9. After the burning is completed, replug the USB device. In Linux • 1. Enter dfu mode Short-circuit the boot's two pins, and then connect it to the computer via USB • 2. Use apt-get for installation of dfu-util Apt-get install dfu-util • 3. Use upload.py for firmware upgrade (requires root privileges) • 4. Firmware update. Click to download. Open the terminal and enter into the newly downloaded firmware directory (DFRobot_RaspberryPi_TouchScreen_Firmware/linux) Use sudo python upload.py to run the program. • 5. Replug the USB device. In Mac • 1. Enter dfu mode Short-circuit the boot's two pins, and then connect it to the computer via USB • 2. Open the terminal Open the launcpad Search for "terminal" on the top of the screen. Open the terminal • 3. Install dfu-util brew install dfu-util • 4.Use upload.py for firmware upgrade (requires root privileges) • 5. Firmware update. Click to download Open the terminal and enter into the newly downloaded firmware directory (DFRobot_RaspberryPi_TouchScreen_Firmware/linux) Use sudo python upload.py to run the program。 • 6. Replug the USB device https://wiki.dfrobot.com/7''_HDMI_Display_with_Capacitive_Touchscreen_SKU__DFR0506/8-20-20
DFR0506 价格&库存
很抱歉,暂时无法提供与“DFR0506”相匹配的价格&库存,您可以联系我们找货
DFR0506
库存:51
