DFR0518
DFR0518
    DFROBOT
    Micro:Mate 扩展 连接性 micro:bit 平台评估扩展板
DFR0518 数据手册
Micro:Mate- A Mini Expansion Board for micro:bit SKU: DFR0518 Introduction Micro: Mate is a tiny micro: bit I/O expansion board for learning electronics and building DIY projects. Micro:Mate expands 6 sets of 3-pin I/O interfaces, capable of connecting DFRobot Gravity series modules, servo motors, sensors and jumper wires. Additionally, Pin 8, 12, 16 support voltage switch between 3V-5V, allowing up to 5V 2A digital (PWM) output. Micro:Mate is in the same dimension of micro: bit. It connects to micro: bit through contact pins (with spring loaded), ensuring easy, compact and secure connection. The rubber bumpers and the 3.5mm audio jack on the back side keep the expansion installed stably on the board, meanwhile prevents reversed connection. NOTE: 1. The mounting screws should be well tightened to ensure a secured connection. 2. Micro: Mate only supports 3V (3.3V) analog input from Pin 0, 1, 2. The Micro USB Power port on Micro: Mate cannot be used for data transmission. 3. Components with large power consumption should be connected to Pin 8, 12, 16, with 5V power supply. Specification • • • • • • Interface: 6 x Gravity 3Pin Operating Voltage: 5V/3.3V Input Power: { basic.pause(1000) pins.servoWritePin(AnalogPin.P8, 0) basic.pause(1000) pins.servoWritePin(AnalogPin.P8, 90) basic.pause(1000) pins.servoWritePin(AnalogPin.P8, 180) basic.pause(1000) pins.servoWritePin(AnalogPin.P8, 90) }) BXY micro:bit Python editor #http://docs.dfrobot.com.cn/bxy/examples/servo.html from microbit import * import Servo sv=Servo(pin8) while True: sv.angle(0) sleep(1000) sv.angle(90) sleep(1000) sv.angle(180) sleep(1000) sv.angle(90) sleep(1000) Expected Results The Servo turns back and forth from 0-180 in every 4 seconds More Documents • Schematic & Layout https://www.dfrobot.com/wiki/index.php/Micro:Mate-_A_Mini_Expansion_Board_for_micro:bit_SKU:_DFR0518 4-3-18
DFR0518 价格&库存
很抱歉,暂时无法提供与“DFR0518”相匹配的价格&库存,您可以联系我们找货
DFR0518
  • 1+46.16454
库存:33
DFR0518
  • 1+51.733001+6.72520
