DFR0521
DFR0521
    DFROBOT
    Boson,Gravity 转 micro:bit 连接性 micro:bit 平台评估扩展板
DFR0521 数据手册
        micro:bit Expansion Board for Boson (Gravity Compatible) SKU:DFR0521     INTRODUCTION micro:bit is a pocket-sized microcontroller designed for kids and beginners to learn coding and electronics, letting them easily bring ideas into DIY digital games, interactive projects and robotics. Micro:bit However, on-board I/O rings and crocodile clips sometimes are not handy and safe enough to connect peripherals. To explore more possibilities with micro:bit, we have designed the micro:bit Expansion Board for Boson, a carry-on board that connects to micro:bit via edge conector. The expansion board comes with 6 fool-proof 3-Pin sockets, compatible with hundreds of DFRobot’s Boson and Gravity modularized electronic blocks, covering most popular digital and analog sensors and actuators, supporting sound, light and motion interaction. Click the link to learn more about DFRobot’s Boson module: https://www.dfrobot.com/boson Click the link to learn more about DFRobot’s Gravity module: https://www.dfrobot.com/gravity Moreover, the on-board 3.5MM headphone jack and volume knob supports direct connection of headphone. To ensure a steady current supply for these peripherals, the expansion board can be powered externally through the USB power port. micro:bit Boson game pad micro:bit RGB LED heart rate monitor Gravity electronic module recommendation (micro:bit compatible): Digital Capacitive Touch Sensor Digital PIR (Motion) Sensor Analog Rotation Potentiometer Digital Speaker Module Analog Grayscale Sensor Analog Sound Sensor Joystick Module Analog Slide Position (Potentiometer) Sensor Heart Rate Monitor FEATURES  3-Pin fool-proof connector x 6  Headphone jack with volume knob  External power port and ON/OFF switch  DFRobot Gravity and Boson electronic module compatible SPECIFICATION  MicroUSB Power Port Voltage:5V  PH2.0 Input/output Voltage: 3.3V  Input/output ring Voltage: 3.3V  Maximum Current: 500mA  Working temperature: 0-85 Ԩ  Dimension 80 * 70 mm / 3.15 * 2.76  Weight: 48g SHIPPING LIST  micro:bit Expansion Board for Boson x 1  200mm fool-proof PH2.0 cable x 6        https://www.dfrobot.com/product‐1637.html 11‐2‐17
DFR0521 价格&库存
很抱歉,暂时无法提供与“DFR0521”相匹配的价格&库存,您可以联系我们找货
DFR0521
  • 1+72.28158
库存:8
