DFR0522
DFR0522
    DFROBOT
    GRAVITY: I2C 8X16 RGB LED MATRIX
DFR0522 数据手册
Gravity: I2C 8x16 RGB LED Matrix Panel SKU: DFR0522 Introduction Single color dot matrix LED displays are common in the market while small RGB displays are in short supply. This Gravity: I2C 8x16 RGB LED Matrix Panel produced by DFRobot has 7 colors and more than 20 images in default, supporting user-defined image setting. It can also show Numbers, Letters and Symbols, and support display scroll. Controlled by IIC agreement, Gravity: I2C 8x16 RGB LED Matrix Panel is easy to connect and convenient to control. Just a special Arduino library can accomplish all designs, which totally free from complex wiring and codes. It can be widely applied to projects like robots, smart home monitoring systems and toy cars… Specification • • • • • • Operating Voltage: 5.0V Operating Current: ≤150mA Communication: IIC/I2C LED Backlight: RGB Adjustable (7 colors) Operating Temperature: 0-70℃ Size: 2.44in x 1.06in (62mm x 27mm) PinOut Gravity-I2C 8x16 RGB LED Matrix Panel Back Num Label Description 1 + + 2 - - 3 C IIC Clock Line 4 D IIC Data Line Built-in Images Gravity-I2C 8x16 RGB LED Matrix Panel Built-in Images Colors Gravity-I2C 8x16 RGB LED Matrix Panel Colors Library Functions Print String Prototype:void print(String ,unsigned char color) • • • • • • • • • • • Function: Print a string in the panel. Parameters: String: string, with “ ” enclosed Color: color to show Red: RED Green: GREEN Yellow: YELLOW Blue: BLUE Purple: PURPLE Cyan: CYAN White: WHITE E.g. #include #include DFRobot_RGBPanel panel; void setup() { } void loop() { panel.print("DF1", BLUE); //Display DF1 in BLUE } Print Numbers and Variables Prototype:void print(int val,unsigned char color) • • • • • • • • • • • Function: Print Numbers and Variables in the plane. Parameters: Val: int values or int variables Color: color to show Red: RED Green: GREEN Yellow: YELLOW Blue: BLUE Purple: PURPLE Cyan: CYAN White: WHITE E.g. #include #include DFRobot_RGBPanel panel; void setup() { } void loop() { int a=12; panel.scroll(Left); panel.print(a, BLUE); //Print variable a in BLUE. while(1); } Scroll Display Prototype:void scroll(unsigned char dir) • • • Function: Scroll Display Parameters: Scroll in left: Left • • Scroll in right: Right Stop scroll: None E.g. #include #include DFRobot_RGBPanel panel; void setup() { } void loop() { panel.scroll(Left); //Set to scroll in left panel.print("DFRobot", BLUE); //Show "DFRobot" in BLUE while(1); } Display Pixels Prototype:void pixel(unsigned char x,unsigned char y,unsigned char color) • • • • • • • • • • • • Function: Spicify a pixel to show Parameters: x:pixel position in x direction(value:0~7) y:pixel position in y direction(value:0~15) Color: color to show Red: RED Green: GREEN Yellow: YELLOW Blue: BLUE Purple: PURPLE Cyan: CYAN White: WHITE E.g. #include #include DFRobot_RGBPanel panel; void setup(){ Serial.begin(9600); } // Set the 1st LED to off, other 7 LEDs show GREEN, YELLOW, BLUE, PURPLE, CYA N, WHITE respectively. void loop(){ panel.pixel(0,0,QUENCH); panel.pixel(0,1,RED); panel.pixel(0,2,GREEN); panel.pixel(0,3,YELLOW); panel.pixel(0,4,BLUE); panel.pixel(0,5,PURPLE); panel.pixel(0,6,CYAN); panel.pixel(0,7,WHITE); } Clear Display Prototype:void clear(); • Function: Clear the display. • Parameters: None E.g. #include #include DFRobot_RGBPanel panel; void setup(){ } //Show"DF1"in the panel and flash in every second. void loop(){ panel.print("DF1", BLUE); delay(1000); panel.clear(); delay(1000); } Show All Prototype:void fillScreen(unsigned char color) • • • • • • • • • • Function: Parameters: Color: color to show Red: RED Green: GREEN Yellow: YELLOW Blue: BLUE Purple: PURPLE Cyan: CYAN White: WHITE E.g. #include #include DFRobot_RGBPanel panel; void setup(){ } //Fill in the display panel in BLUE and flash in every second. void loop(){ panel.fillScreen(BLUE); delay(1000); panel.clear(); delay(1000); } Show Built-in Images Prototype:void display(unsigned char picIndex,unsigned char color) • • • • • • • • • • Function: show built-in 23 images in the display panel, number as 0~22. Parameters: Color: color to show Red: RED Green: GREEN Yellow: YELLOW Blue: BLUE Purple: PURPLE Cyan: CYAN White: WHITE E.g. #include #include DFRobot_RGBPanel panel; void setup(){ Serial.begin(9600); } //Show No.3 image in RED and flash in every second. void loop(){ panel.display(3,RED); delay(1000); panel.clear(); delay(1000); } Tutorial Connect hardware accoridng to the PinOut instruction, download Sample Code to the DFRduino UNO R3 (or similar), upload successfully. Then RGB Maxtrix colorful effect could be seen. Requirements • • • • Hardware DFRduino UNO R3 (or similar) x1 Gravity: I2C 8x16 RGB LED Matrix Panel x1 IIC Data Line x1 • • Software Arduino IDE (Version requirements: V1.6.+), Click to Download Arduino IDE from Arduino® Connection Diagram Sample Code Click to download libraries and examples. How to install Libraries in Arduino IDE. /*! * file DFRobot_RGBPanel_IIC_demo.ino * * connect RGBPanel and Arduino ,then download this example * * Copyright [DFRobot](http://www.dfrobot.com), 2016 * Copyright GNU Lesser General Public License * * version * date V0.1 2017-11-15 */ #include #include DFRobot_RGBPanel panel; void setup() { } void loop() { String s = "DFRobot"; //Define the string"DFRobot" panel.clear(); //Clear the display. panel.fillScreen(RED); //Fill in the display in RED for 2s. delay(2000); panel.clear(); //Clear the display. panel.fillScreen(GREEN); //Fill in the display in GREEN. delay(2000); //Show GREEN for 2s. panel.clear(); panel.fillScreen(BLUE); //Fill in the display in BLUE for 2s. delay(2000); panel.clear(); panel.scroll(Left); //Set to scroll in left panel.print(s, RED); //Show "DFRobot" in RED while(1); } Expected Results Result: Fill in RGB LED Panel in RED, GREEN and BLUE respectively, and show ”DFRobot”. More Documents • Hardware Design Resource https://www.dfrobot.com/wiki/index.php/Gravity:_I2C_8x16_RGB_LED_Matrix_Panel_SKU:_DFR0522 6-5-18
DFR0522 价格&库存
很抱歉,暂时无法提供与“DFR0522”相匹配的价格&库存,您可以联系我们找货
