DFR0528
DFR0528
    DFROBOT
    MAX17043 不间断电源(UPS) 电源管理 Raspberry Pi Zero 平台评估扩展板
DFR0528 数据手册
    UPS HAT for Raspberry Pi Zero SKU:DFR0528   INTRODUCTION DFRobot UPS HAT is an uninterruptable power supply shield designed for the Raspberry Pi Zero series, and also compatible with Pi 2/3/A+. The UPS HAT can continue to provide power to the Raspberry Pi for a certain period of time when the system is powered off, by which to avoid system damage and assure safe shut down. In addition, the product can be used to supply power for applications requiring mobility such as Raspberry Pi camera, tablet PC, field data collection system. FEATURES    Standard Raspberry Pi extension ports for connecting other expansion boards.  2A maximum current output for supporting more Raspberry Pi applications.  Auto switching of charge/recharge path, designed to be against power-down.  On-board 5 LEDs for showing the batteries’ status  On-board Maxim fuel gauge IC  Support reading battery information via I2C  Lithium battery charge/discharge protection and over-heating protection  Anti-backflow mainboard power source   SPECIFICATION  Supply Voltage: 4.5~5.5V  Supply Current: (recommend using the adapter with the power of 2A and above)  Power Supply Interface: Micro-USB  Maximum Charge Current: 1.6A  Battery Port: PH2.0-2P or solderable contact  Battery: 3.7 Lithium Battery  Output Voltage: 5V  Maximum Output Current: 2A  Communication Interface: I2C  Dimension: 65x30mm/2.56x1.18”  Mounting Hole Size: 58x23mm/2.83x0.91”  Operating Temperature: -40℃~85℃ SHIPPING LIST  UPS HAT for Raspberry Pi Zero x1  Double-pass Copper Pillar M2.5*14 x4  Single Head Copper Pillar M2.5*4 x4  Screw M2.5*6 x4   https://www.dfrobot.com/product‐1932.html?search=DFR0528&description=true/12‐5‐19
DFR0528 价格&库存
很抱歉,暂时无法提供与“DFR0528”相匹配的价格&库存,您可以联系我们找货
DFR0528
  • 1+230.848811+29.92240
库存:3
DFR0528
  • 1+175.401111+22.73533
库存:32
