5''TFT-Display with Touchscreen V1.0
SKU:DFR0550
This is a 5" Raspberry Pi LCD touchscreen with 800*480 resolution and 108×64.8mm display area.
The product supports Raspberry Pi DSI display interface and comes with a capacitive touch panel
on its screen and supports 5 touch points. The special holes design on the back of the screen is
convenient to directly install the Raspberry Pi in the product. There is no need to provide external
power for the touchscreen as the Raspberry Pi power supply is adopted. In addition, the screen
supports hardware backlight adjustment. The function can be realized by turning the potentiometer
on the back of the display.
Features
Capacitive Touchscreen, Support 5 TouchPoints.
Raspberry DSI Direct Driver
Specification
Operating Voltage: 3.3V (Supplied by Raspberry Pi display interface)
The Maximum Operating Current: 320mA
Screen-off Current: 100mA
Resolution: 800*480
Video Interface: Raspberry Pi DSI
Number of Touch Points: 5
Viewing Angle: 60°/70°/70°/70°
RGB888-16 Mega True Color
Refresh Frequency: 60Hz
Luminous Efficiency: 280 cd/m2
Operating Temperature: -20Ԩ~70Ԩ
Dimension: 121mm×76mm / 4.76" × 2.99"
Mounting Hole Size: M2.5
Outside Mounting Hole Position: 113mm × 68mm/ 4.45" × 2.68"
Inside Mounting Hole Position: 58mm x 49mm/ 2.28" x 1.93"
Board Overview
The back of the 5" touchscreen
DISPLAY interface can be connected to Raspberry Pi’s DISPLAY interface via FPC wiring.
The Touchscreen’s brightness can be adjusted via a potentiometer.
Tutorial
Step 1. Insert an SD card that with a Raspberry Pi system into Raspberry PI.
Insert SD card
Step 2. Connect display interface of the 5" touchscreen to that of Raspberry Pi via a provided FPC
wiring.
Connect DISPLAY interface
Step 3. Connect Raspberry Pi to the power supply, and then you can use the touchscreen.
Dimension Diagram
5" touchscreen dimension diagram, click to enlarge
https://www.dfrobot.com/wiki/index.php/5%27%27TFT‐Display_with_Touchscreen_V1.0_SKU:DFR0550 9‐11‐18
很抱歉,暂时无法提供与“DFR0550”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+441.889731+57.28493
