DFR0553
DFR0553
    DFROBOT
    ADS1115 模数转换器(ADC) 数据采集 Gravity 平台评估扩展板
DFR0553 数据手册
        Gravity: I2C ADS1115 16-Bit ADC Module(Arduino & Raspberry Pi Compatible) SKU: DFR0553       DFRobot I2C ADS1115 16-bit ADC module can accurately collect and convert analog signals. Through this ADC module, Raspberry Pi can easily use a wide range of Gravity series analog sensors to measure various signals, and perceive this world. Raspberry Pi is a common master control board which is powerful in its functions, but the I/O pins of Raspberry Pi can read digital signals only, what's more, only through an external analog-to-digital conversion (ADC) module can it read signals of analog sensor or device, it is not convenient to use. DFRobot I2C ADS1115 16-bit ADC module is specially designed for Raspberry Pi and Gravity series analog sensors, which greatly reduces the difficulty of using the Gravity series analog sensors, plug and play, no welding, very convenient. The number of Gravity series sensors is large and its wide variety can meet the needs of various sensors of the Raspberry Pi. This module uses 16-bit ADC chip ADS1115, supports 3.3 ~ 5V wide voltage power supply. The chip has a precision reference voltage and programmable gain adjustment (PGA), therefore, accurate acquisition and conversion can be performed for both weak and highly variable signals. So it is also applicable to all types of applications that the main control board needs to accurately collect the analog signals. One ADC module can read analog signals of 4 channels. Because of the onboard I2C address selection switch, it supports the cascade of two ADC modules and can read analog signals of 8 channels, it can satisfy the needs of various applications. Specification         Supply Voltage (VCC): 3.3~5.0V Analog Signal Detection Range: 0~VCC Number of Analog Channels: 4 ADC Bits: 16 Bit Operating Current: 2~3mA (Not include sensor module) Interface Type: Gravity I2C Interface Level: High 3.3V, Low 0V Product Size: 32mm * 32mm(1.26in*1.26in) Board Overview Gravity: I2C ADS1115 16-Bit ADC Module(Arduino & Raspberry Pi Compatible) Num + C D A ADDR Label VCC GND SCL SDA Analog In I2C Address Description Power VCC(+3.3~5.0V) Power GND(0V) I2C Bus Clock Line I2C Bus Data Line Analog Input Channels: A0, A1, A2, A3 I2C address selection switch,I2C address: 0x48, 0x49 Tutorial The voltage on analog input pins must be less than VCC+0.3V! That is, Analog Signal ≤ VCC+0.3V Arduino Tutorial This tutorial will demonstrate how to use the ADC module to read 4 channels analog signals with the Arduino board. Please switch the I2C address to 0x48. Requirements      Hardware DFRduino UNO R3 (or similar) x 1 I2C ADS1115 16-bit ADC Module x 1 Analog Sensors(sound, voltage, temperature, ambient light, etc.) x4 Gravity 4pin Cable (or several DuPont cables) x1   Software Arduino IDE (Version requirements: V1.0.x or V1.8.x), Click to Download Arduino IDE from Arduino® Connection Diagram Sample Code Please down the DFRobot_ADS1115 Library and install it. How to install Libraries in Arduino IDE Description of the I2C Address in this Library:   ADS1115_IIC_ADDRESS0:0x48 ADS1115_IIC_ADDRESS1:0x49 /* * file ADS1115_ReadVoltage.ino * * @ https://github.com/DFRobot/DFRobot_ADS1115 * * connect ADS1115 I2C interface with your board (please reference board c ompatibility) * * The voltage value read by A0 A1 A2 A3 is printed through the serial por t. * * Copyright [DFRobot](http://www.dfrobot.com), 2016 * Copyright GNU Lesser General Public License * * version * date V1.0 2018-01-21 */ #include #include DFRobot_ADS1115 ads; void setup(void) { Serial.begin(115200); ads.setAddr_ADS1115(ADS1115_IIC_ADDRESS0); ads.setGain(eGAIN_TWOTHIRDS); ads.setMode(eMODE_SINGLE); // 0x48 // 2/3x gain // single-shot mode ads.setRate(eRATE_128); // 128SPS (default) ads.setOSMode(eOSMODE_SINGLE); // Set to start a single-conversion ads.init(); } void loop(void) { if (ads.checkADS1115()) { int16_t adc0, adc1, adc2, adc3; adc0 = ads.readVoltage(0); Serial.print("A0:"); Serial.print(adc0); Serial.print("mV, "); adc1 = ads.readVoltage(1); Serial.print("A1:"); Serial.print(adc1); Serial.print("mV, "); adc2 = ads.readVoltage(2); Serial.print("A2:"); Serial.print(adc2); Serial.print("mV, "); adc3 = ads.readVoltage(3); Serial.print("A3:"); Serial.print(adc3); Serial.println("mV"); } else { Serial.println("ADS1115 Disconnected!"); } delay(1000); } Expected Results Raspberry Pi Tutorial This tutorial will demonstrate how to use the ADC module to read 4 channels analog signals with Raspberry Pi. Please switch the I2C address to 0x48. Requirements      Hardware Raspberry Pi 3 Model B (or similar) x 1 I2C ADS1115 16-bit ADC Module x 1 Analog Sensors(sound, voltage, temperature, ambient light, etc.) x4 Gravity 4pin Cable (or several DuPont cables) x1    Software DFRobot_ADS1115 Raspberry Driver RASPBIAN Connection Diagram Install Driver  1.Open the Raspberry Pi I2C interface. If it is already open, skip this step. Open Terminal, type the following command, and press Enter: sudo raspi-config Then use the up and down keys to select “5 Interfacing Options”, press Enter, select “P5 I2C” and press Enter to confirm “YES”. Restart the Raspberry Pi.  2. Install the Python related libraries and git, then Raspberry Pi requires networking. If it is already installed, skip this step. In the terminal, type in the following commands in order, and press Enter: sudo apt-get update sudo apt-get install build-essential python-dev python-smbus git  3. Download the driver and run. In the terminal, type in the following commands in order, and press Enter. cd ~ git clone https://github.com/DFRobot/DFRobot_ADS1115.git cd DFRobot_ADS1115/RaspberryPi/Python sudo python DFRobot_ADS1115.py Run the Sample Code  In the terminal, type the following commands in order, and press Enter: cd ~/DFRobot_ADS1115/RaspberryPi/Python/ADS1115_ReadVoltage sudo python ADS1115_ReadVoltage.py Expected Results                       https://www.dfrobot.com/wiki/index.php/Gravity:_I2C_ADS1115_16‐Bit_ADC_Module(Arduino_%26_Raspberry_Pi_Compatible)_SKU:_DFR0553  6‐5‐18
DFR0553 价格&库存
很抱歉,暂时无法提供与“DFR0553”相匹配的价格&库存,您可以联系我们找货
